Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-25-2003, 03:10 AM   #1
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default How to: Remove your L98 smog equipment: PICS inside
I removed all this crap from my Corvette today:
Click the image to open in full size.
The air tube going across the front of the engine was a PITA to remove. But I was persistent. I had to remove the fan, the fuel lines, pull the A/C forward, and remove the water pump pulley to get to it (in addition to all the other crap on top of that.)
The smog pump had 6 teflon pieces inside the walls of the rotor (not pictured), that the fins slide against when turning. If you break the fins out, but don't remove these pieces, they can potentially come out, or jam, or rattle and make more noise than it did to begin with. And they're a pain to remove. Save the hassle and buy a smog pump eliminator pulley kit.
Here's the engine afterwards:
You can see here that I used 1/2" stainless steel caps to plug the air injection lines on the ported headers. (Those are FACTORY headers by the way!) I didn't bother blocking off the smog pump outlet, since it no longer pumps air with the fins removed. I also pulled the AIR line to the cat. I plugged the hole with a fine thread bolt of the correct size, and some Copper RTV.
I plan on replacing the catalytic converter with a test pipe, or just getting whole new exhaust, (when I land a job.) I haven't pulled anything off that I can't put back on. When I have to smog it next year, I'll try a pretest with the smog stuff off to see if I pass. I might even sneak past the visual if the tech isn't up to snuff. Worst case scenario, I have to spend a few hours bolting that box of crap back onto it! :auto:
CentralCoaster is offline   Reply With Quote
Old 09-25-2003, 06:00 AM   #2
Steel Blue 91
CF Senior Member
Steel Blue 91's Avatar
Default Re: How to: Remove your L98 smog equipment: PICS inside (CentralCoaster)
Nice work Kevin. Sure does clean up the engine compartment. I was thinking of doing the same thing, but I need to pass the smog every year.
Steel Blue 91 is offline   Reply With Quote
Old 09-25-2003, 10:10 AM   #3
AGENT 86
CF Senior Member
AGENT 86's Avatar
:cool:
Your so far ahead on your list that i'll never catch up :smash:
:cheers:
AGENT 86 is offline   Reply With Quote
Old 09-25-2003, 12:49 PM   #4
oldace84
CF Senior Member
St. Jude Donor '04 & '05
oldace84's Avatar
Kevin,
Great job.
But how are you going to get by the Smog Nazi's?
I think your in CA.
If theres a secret let me know.
thanks
tony
:flag
oldace84 is offline   Reply With Quote
Old 09-25-2003, 12:57 PM   #5
Unriced
CF Senior Member
Unriced's Avatar
Send a message via AIM to Unriced
How do you deal with the check engine light from removing the air control valve and burn off mod?
Unriced is offline   Reply With Quote
Old 09-25-2003, 02:30 PM   #6
Vettski
Junior Member
Vettski's Avatar
Nice job :cool: Is there any HP increase with all that junk off?
Vettski is offline   Reply With Quote
Old 09-25-2003, 03:36 PM   #7
J Z06
CF Senior Member
J Z06's Avatar
Send a message via AIM to J Z06
It really neatens the passenger side.
I especially like the look of the smog pump elim. :cheers:
J Z06 is offline   Reply With Quote
Old 09-25-2003, 03:43 PM   #8
CentralCoaster
CF Senior Member
Default Re: How to: Remove your L98 smog equipment: PICS inside (Jay 383)
:confused: I just gutted it. But yeah, an elim would be nice on there. In fact, before I did that, I'd just fab up my own bracket for the alternator and move it... or something to that effect.
UnRiced: Removing the AIR diverter solenoids does not throw a code. (Which shows you how much GM cares about California asinine smog laws. :rolleyes: ) Just make sure you plug the vacuum line going to them, or remove it completely and hook the fuel pressure reg directly to the forward vacuum port on the side of the plenum.
Old 09-25-2003, 03:46 PM   #9
CentralCoaster
CF Senior Member
BTW, the smog pump has a pretty hefty rotor in it. I'm guessing the rotating mass take almost as much energy to overcome as it pushing air with the fins.
It's basically equivalent to a 'frisbee' as far as the belt system is concerned, but not as easily circumvented.
Old 05-09-2011, 12:38 PM   #10
RedBowTies88
CF Member
Holy old thread batman!
if the OP is still around any chance you could re add the pics if you have them?
RedBowTies88 is offline   Reply With Quote
Old 05-09-2011, 12:48 PM   #11
cuisinartvette
CF Senior Member
St. Jude Donor '05
hes on c4guru. com no longer here.
cuisinartvette is offline   Reply With Quote
Old 05-09-2011, 12:52 PM   #12
RedBowTies88
CF Member
10-4, thanks
Reload this Page How to: Remove your L98 smog equipment: PICS inside
Tags
acsmog, air, corvette, delete, eliminate, eliminator, equip, gain, hp, l98, pump, remove, removing, smog, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
