Coding "22" = Throttle position sensor is low????????
:mad have went thru and cleaned the throttle bodies, new IAC's, new plugs, and because of a booboo-replaced the tv/kickdown cable, and took it out for a test run...and NOTTA!!!! wont shift right...wont idle ...wont recognize overdrive. almost think the crazy ride drove better before the t.l.c. ha ha !!!! it didnt code before, and now it is coding "22"?? HELP!!!!!! any ideas on where to go from here. Appreciate your responses as always, am learning so much about this vehicle it is almost scarey.....
p.s. hubby wants to know how to adjust tv/kickdown cable.
Re: Coding "22" = Throttle position sensor is low???????? (jennykayes84vette)
the throttle position sensor is attached to the pass. side of the throttle body. It is adjustable. Properly re-adjusting it should make this code go away. If it doesnt then i would replace the throttle position sensor.
Re: Coding "22" = Throttle position sensor is low???????? (Wheelman)
Here i found this link for ya this should help you get your tps properly readjusted. http://www.geocities.com/jgkov/TPSService.html
:thumbs: thanks for the info! it is late here in oklahoma, but will get a voltmeter tomorrow and get after the steps stated on the link u gave me to adjust the tps! appreciate the help!!!!!
:D
:D
