BLM 116, is it a problem?
Old 08-27-2003, 01:51 PM
dave_85
dave_85's Avatar
Default BLM 116, is it a problem?
I finally got my cheep ebay IBM ThinkPad working with WinALDL. :hurray: Who knew that you needed a special ThinkPad Configuration tool to turn on the serial port. :confused: Any way at idle my BLM is 116. It’s an 85 so only one O2 sensor. Looks like I am a little rich. I have Ford 21 lb. injectors and 40psi fuel pressure. Is this anything to worry about. How low can I go with the fuel pressure.
Old 08-27-2003, 10:14 PM
wombvette
wombvette's Avatar
Default Re: BLM 116, is it a problem? (dave_85)
The combination of higher pressure and injectors would likely make the computor sense a rich condition. I would look at how many changes (counts) that the OX sensor goes from rich to lean. If it is changing back and fourth, it will probably be OK.
Old 08-27-2003, 11:33 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Back off fuel pressure to around 30psi and see where the BLM value goes after a few minutes.
I think your stock FP was only around 38psi with 22lb/hr stock injectors.
To tune the fuel flow at WOT, adjust fuel pressure till you see an O2 value of around 920mv at WOT.
Old 08-28-2003, 12:31 AM
MrNuke
MrNuke's Avatar
Default Re: BLM 116, is it a problem? (65Z01)
38psi@24lbs was stock for '85.
If anything with 21kbs injectors you shoudl be lean, not rich..
Old 08-28-2003, 09:24 AM
dave_85
dave_85's Avatar
Default Re: BLM 116, is it a problem? (MrNuke)
I drove it around with the BLM chart turned on. I saw lots of points where BLM is between 124 - 128'. The rich/lean counter changes often to. I think I am OK with the fuel pressure.
One thing I saw in the flag data was ".DRP occured". What is a DRP?
This WinALDL scanner is very cool. Thank You Jonas. :cheers:
Old 08-28-2003, 10:01 PM
Kendall
Kendall's Avatar
If your BLMs are okay on the road don't worry. My 89 does the same thing. The GM man told me they did that to help cool down a hot motor.
Old 08-28-2003, 10:13 PM
scorp508
scorp508's Avatar
Jim, per my other post here what have you witnessed 920mv being approximate to in A/F ratio terms? I want to richen my 870mv a hair more.
Old 08-29-2003, 01:15 PM
dave_85
dave_85's Avatar
Default Re: BLM 116, is it a problem? (scorp508)
I have a chart of O2 Voltage vs AF Ratio and 920mV looks like 13.5 A/F.
Old 08-29-2003, 01:19 PM
scorp508
scorp508's Avatar
Would you mind sharing?
Old 08-29-2003, 01:30 PM
dave_85
dave_85's Avatar
I found it at http://www.carlton24v.co.uk/datasheets/o2sensors.pdf
To BLM 116, is it a problem?
Quick Reply: BLM 116, is it a problem?
