Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-25-2003, 02:35 PM   #1
B84RADR
CF Senior Member
Support Corvetteforum!
B84RADR's Avatar
Send a message via MSN to B84RADR
Default After antifreeze mixed in with the oil, does that ruin the engine?
I only had it running at an idle for a minute at this while we were trying to troubleshoot why it was running so badly.
Needless to say, I switched the oil and filter immediately. The oil was a coffee-cream color.
Could that ruin the engine right there? I have a buddy telling me it can, that it breaks down the oil and ruins the cylindar walls. What do you think?
B84RADR is offline   Reply With Quote
Old 07-25-2003, 05:01 PM   #2
B84RADR
CF Senior Member
B84RADR's Avatar
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (sspackman)
I should also mention it backfired a few times really bad and I hear that this can cause a head gasket to go quicker than anything. It was never in drive, only idle this first time. And then I shut it down and took it all back apart.
Old 07-25-2003, 05:16 PM   #3
NOT-MEE
CF Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
NOT-MEE's Avatar
Send a message via AIM to NOT-MEE
was the timing off is that why it backfired .I have had collant in the oil before when i was doing a headgasket .Never drove far usally to get timing set and test my work and the quickly canged it and it was all good motor ran fine.It would not be good to drive up and down the street with the water there but i think you will be ok.
NOT-MEE is offline   Reply With Quote
Old 07-25-2003, 05:17 PM   #4
ZylaRace
CF Senior Member
ZylaRace's Avatar
Backfire ruin a head gasket while idleing,.... An NA non-NOS engine,... no not unless it was bad to begin with.
Coolant ruin an engine,.... no. It is not what you want happening,... but there is no need to throw it all away. Do you have new rings in there? W/ a little luck, they will still seat.
It all comes down to how long the engine ran w/ coolant in the oil. How heavy was the engine loaded while it ran thsi way. How much coolant in the oil are we talking about.
If you description is accurate,... fix the coolant leak, and you sould be fine.
Been there done that.
ZylaRace is offline   Reply With Quote
Old 07-25-2003, 05:24 PM   #5
B84RADR
CF Senior Member
B84RADR's Avatar
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (ZylaRace)
It wasn't run for very long. As a matter of fact, it was pretty tough to even keep it running at all because the intake hadn't sealed correctly and everything was running everywhere. I guess my friend was just a little concerned. Concerned enough to tell me that he thought I had hurt other things in the engine other than just the coolant mixing in with the oil.
Question is: Now that it's happened. What steps do I follow next? Will there possibly still be coolant in any of my cylindars? Hell, I drove the car to work today and it was OK, but not great. If I need to do something, I have the tools with me right now to do it.
Thanks!
Shayne
Old 07-25-2003, 06:24 PM   #6
Rich B.
CF Senior Member
Rich B.'s Avatar
:iagree: Me, too! Buick V-6 head gasket rusted out; oil in water, water in oil.
New head & intake gaskets and oil & filter change (twice) and it was fine.
[Modified by Rich B., 6:25 PM 7/25/2003]
Rich B. is offline   Reply With Quote
Old 07-25-2003, 06:29 PM   #7
scorp508
CF Senior Member
scorp508's Avatar
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (Rich B.)
If you let it sit there for quite a while the bearings would start to rust up from the sugar in the coolant. You should be fine though. Heck I had coolant shooting out my tailpipes last year. :D
scorp508 is offline   Reply With Quote
Old 07-25-2003, 06:32 PM   #8
edsalinas
CF Senior Member
St. Jude Contributor
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (scorp508)
:iagree:
edsalinas is offline   Reply With Quote
Old 07-25-2003, 07:06 PM   #9
B84RADR
CF Senior Member
B84RADR's Avatar
That sounds reasonable!!! Out of your tailpipes, that was after the bolt though, right? Or did you just blow a gasket?
I just want to make sure from everyone up here now that the knowledge is out there that I got coolant into the oil system that I don't need to purge anything out of my cylindars or do anything else. I don't know all about this hydrolock but I hear it can be a real beotch. That's why I'm checking.
Thanks! :cheers:
p.s. I'm still taking the car down to a shop I trust that knows Corvettes really well on Monday and they are going to go through it and make sure it all looks good.
Old 07-26-2003, 03:10 AM   #10
mitymek
CF Senior Member
Send a message via ICQ to mitymek
if it gets in the cylinders you can easily bend a rod.
if you hit the starter and it just clunks (ever),dont try it again.
immediately pull the plugs out and turn it over.
if theres coolant in there itll blow out the holes.
antifreeze wont hurt the rings (to my knowledge)but i have seen it etch the cylinder walls with a strange looking pattern before.
probly harmless.
what it does do thats bad is attacks the coatings on the bearing shells.
on big diesel engines a common practice to remove the coolant residue in the oil areas is to run some butyl seldesol in with fresh oil,then change it several times in a row.
cat/cummins engines dont drain completely when you drop the oil due to many places in the castings that hold oil so thats proly another reason to use a "gatherer" agent on them.
i think your probly fine just changing the oil a couple of times.
howd the coolant get there?
mitymek is offline   Reply With Quote
Old 07-26-2003, 05:07 AM   #11
BIG JIM 54
CF Senior Member
BIG JIM 54's Avatar
FYI,
Common anti-freeze is made up of mostly ethlyene-glycol and dyes acting as a product marker for the various brands. This is mixed with water to makeup the coolant in out cars. Ethlyene-glycol is excellent for this purpose because of it's high boiling point as well as it's good lubrication and rust preventing properties.
Contrary to what was mentioned here, it does not contain sugar (does anyone really believe that?) but it does have a "sweet" smell and it does not cause rust.
If it did cause rust, the bare metal insides of the iron engine block would be the first to suffer. What causes rust is an improper mixture of water and anti-freeze (usually not enough anti-freeze) which lets the water do it's damage.
BIG JIM
BIG JIM 54 is offline   Reply With Quote
Old 07-26-2003, 08:26 AM   #12
Atok
CF Senior Member
Atok's Avatar
Send a message via MSN to Atok
I know water in your oil is very bad for the bearings but since you didn't have the engine under load it'll probably be fine.
A friend of mine runs a shop. One of his employees was pressure testing the cooling system on a 3.8L oldsmobile. The coolant was going somewhere, just couldn't find out where. He kept adding water until he found the leak....when the water came out of the dip-stick he knew where it was. :) After numerous oil changes, running the engine hot, etc. to get the water out of the oil the engine was fine. It's still running today with no unusal sounds.
Atok is offline   Reply With Quote
Old 07-26-2003, 08:36 AM   #13
thepenguin99
CF Senior Member
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (Atok)
As long as it wasnt running very long it should be fine.
On another note, if left for a while coolant/water/oil form kind of a sludge that should not be run as it will stop up your oil pump.
thepenguin99 is offline   Reply With Quote
Old 07-27-2003, 12:57 AM   #14
jefft84
CF Senior Member
jefft84's Avatar
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (thepenguin99)
Short term no problem, it happens all the time when intake or head gaskes fail. The most common problem with oil/water mixture is bearing damage to the soft metals IE copper/tin due to the acidy ph level greated. This takes time, and heat to happen not to mention some more time and combustion gases. So relax if every time water and oil mixed it ruind the engine I would loose alot of income from replacing head and intake gaskets.
jefft84 is offline   Reply With Quote
Old 07-28-2003, 12:10 AM   #15
TheCorvetteKid
CF Senior Member
TheCorvetteKid's Avatar
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (jefft84)
Something similar happened to me. I discovered I had a bad head gasket last spring. I spent all summer and most of the winter tearing out the heads and replacing the head gaskets; the oil pan was just FULL of oil and coolant when I drained the oil!
After finishing the head gasket change and bolting everything back together, I put fresh oil in the engine (regular 5W-30, not Mobile 1), fired it up and set the ignition timing. Once that was done, I ran a bottle of STP Engine Flush through the oil system just to make sure I got as much of the old oil-coolant mix out of my engine as possible. I then drained the oil out, and put fresh new 5W-30 Mobile 1 into the engine, and it's been trouble and hassle free since.
TheCorvetteKid is offline   Reply With Quote
Old 07-28-2003, 12:22 AM   #16
vettek50
CF Senior Member
vettek50's Avatar
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (TheCorvetteKid)
:iagree:
vettek50 is offline   Reply With Quote
Old 07-28-2003, 01:00 AM   #17
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: After antifreeze mixed in with the oil, does that ruin the engine? (vettek50)
When I found coolant in my oil (from the intake leak) I changed the oil a few times and ran it each time to circulate everything and hopefully got any moisture off the bearing surfaces.
Once you get it sealed up and replace the oil, just get it all up to temperature, and all that water will boil away. The antifreeze on the other hand, I dunno, but it won't rust your internals I don't think.
CentralCoaster is offline   Reply With Quote
Old 07-28-2003, 01:52 AM   #18
bill mcdonald
CF Senior Member
BAH!
you'll be fine.
bill mcdonald is offline   Reply With Quote
Old 07-28-2003, 11:33 PM   #19
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
Shayne,
As I said before, the water-antifreeze wasn't in there long enough to hurt anything. A back fire, by definition is an explosion, OUTSIDE of the cylinder. The LAST thing it would hurt, is the head gasket. DO, take it to your trusted mechanic, but I am confident, he'll find nothing seriously wrong. Rest easy, and...
RACE ON!!!
CFI-EFI is offline   Reply With Quote
Reload this Page After antifreeze mixed in with the oil, does that ruin the engine?
Tags
anti, antifreeze, bearings, coolant, damage, engine, freeze, inside, long, mix, mixed, motor, oil, pan, ruin, water
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
