85 oil pressure sensor picture needed.
Can someone please post pictures of the proper orientation of the oil pressure sensor and the fuel pump switch, I need to know which one goes on front and so on. Thanks for the help.
Re: 85 oil pressure sensor picture needed. (CentralCoaster)
Thank you sir. I have another question, What size is the bolt that holds the temp sensor wire holder to the top edge of the block above the starter, it has a small bracket that the wire goes through. Is the bolt hex head ? the temp sensor that goes into the head between the exhaust ports I guess it might be a switch for the fan. anyway enough of my rambling..
