Digital Dash problem...
Old 07-10-2003, 08:11 PM
CarAteMyMoney
CarAteMyMoney's Avatar
Default Digital Dash problem...
First I blew the dash fuse...
..so I put a new one in, and the dash doesnt light up anymore but you can still see the numbers in the background
Also the turn signal indicators are always lit up
Would this be a bad headlight switch? Or something else?
Old 07-10-2003, 08:24 PM
SBNova
SBNova's Avatar
Default Re: Digital Dash problem... (CarAteMyMoney)
Usually if the turn signal indicators are always on its a bad ground. You may have fried the ground when you blew the fuse.
Old 07-10-2003, 08:31 PM
JCAIRE2
JCAIRE2's Avatar
Check this page out: http://www.batee.com/corvette/index.shtml :cheers:
Old 07-11-2003, 11:23 PM
wirenut3
wirenut3's Avatar
Hi mine did the same I have A 86 the connector that plugs into the dash cluster one of the prongs was not making contact hope this helps :cool:
To Digital Dash problem...
Quick Reply: Digital Dash problem...
