Top 5 most beneficial mods to a basically stock C4.
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
1 Post
I was intrigued by the recent post about worthless mods and was curious what you all think are the best mods when you consider the ROI of the mod.
Re: Top 5 most beneficial mods to a basically stock C4. (LT-4 CE)
When you say mods I assume you mean power producing or increased driving pleasure in relation to the cost of the mod. IMO, I would say...
1. N20
2. Exhaust (complete)
3. Cam
4. Gears
5. P&P Heads
Of course, the camber brace and other great "bang for the buck" mods are out there, but don't necessarily produce power or help put it to the ground.
1. N20
3. Cam
4. Gears
5. P&P Heads
Re: Top 5 most beneficial mods to a basically stock C4. (all4c4lt4)
2800 Vigilante Stall Converter
3.73's w/ Dana 44
Exhaust
1.6 Roller Rockers
Hypertech PP3 +
This is for an automatic transmission of course
:thumbs:
3.73's w/ Dana 44
Exhaust
1.6 Roller Rockers
Hypertech PP3 +
:thumbs:
#1 Long tube headers and exhaust seem to free up some nice power, and they don't sound to bad either :thumbs:
#2 If its a TPI, I would then address the stock intake. A SuperRam/MiniRam setup, or if you pockets are light, aftermarket runners and lots of porting.
#3 Gears always seem to wake things up nicely.
#4 If its stick, I would get a Centerforce Clutch. I put them in everything I own. If its Auto, a little more stall speed would be nice.
#5 You can't argue with the $/hp of NOS.
Re: Top 5 most beneficial mods to a basically stock C4. (Ray383)
IMO not all mods=HP:
1. Spare tire delete
2. Headers and cat-back exhaust
3. 13" front brakes
4. ZR-1 wheels (or equivalent)
5. Lowering kit
I am ready to be flamed... :boxing
3. 13" front brakes
5. Lowering kit
My favorite mods so far are the Hurst shifter and the Meziere water pump. I did shortie headers just for heat elim and looks.
Re: Top 5 most beneficial mods to a basically stock C4. (loiq)
3. 13" front brakes
5. Lowering kit
3. 13" front brakes
5. Lowering kit
Yo Yo Yo check it! aight, aight, Big mofok'in wing, code air can, aight! gimme props for da mad pipe! and lay on some decals, nowut'm'sayin'?
:crazy: :crazy:
Re: Top 5 most beneficial mods to a basically stock C4. (vvv90)
:crazy: :crazy:
Re: Top 5 most beneficial mods to a basically stock C4. (Strick)
:confused: ??? What the F This is an English speaking forum, right?
In no particluar order:
Cross Bar from R-D Racing
Camber Brace
Lowering
30mm front sway bar
Firehawk SZ50Ep tires
Remove mufflers.....
:cheers:
Camber Brace
Lowering
30mm front sway bar
:cheers:
Re: Top 5 most beneficial mods to a basically stock C4. (Ruby6spd)
In the case that it's an LT4, and you already have the mods in your sig. I'd add a set of 4.10 gears, as well as Long Tube Headers. Maybe if you wanna delve into the motor, add a LT4 Hot Cam Kit. :cheers:
Re: Top 5 most beneficial mods to a basically stock C4. (shotchkiss)
This is what I have done.
No mufflers - sound good, add a little hp, and reduced weight.
K&N w/ cut lid. - add a little hp, and reduced a couple of lbs.
Spare Tire Delete - reduced weight ALOT
New wires and plugs - get it running back to normal.
New Tires.
New Tires.
1. Meziere (or other electric water pump - LT1).
2. A pair of those clips that actually make the luggage space cover work (no kidding!).
3. Good tires.
4. A good tune-up. Best thing you can do.
5. Driving School.
6. New bushings.
[Modified by John Row, 1:56 PM 7/10/2003]
3. Good tires.
5. Driving School.
6. New bushings.
heads (this where the power is)
cam
exhaust
Gears
suspension
And as vvv90 would say......
tis is duh way dat duh east coast wepresents....if u ain't down wit dis u ain't down..nowut'm'sayin'
cam
exhaust
Gears
suspension
