Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-06-2003, 01:37 AM   #1
Wheelman
CF Senior Member
Wheelman's Avatar
dkredmetallicc4
Send a message via AIM to Wheelman Send a message via Yahoo to Wheelman
Default Whats the best coolant mix for a very hot climate??
As it is now, in the last couple of days my car has been running about 15 degrees hotter than normal on both city and highway, so i decided to pull the radiator and flush the coolant to see if that helps any. Wasnt much in the radiator, i did straighten all the bent fins, so maybe that will help but before i fill it up with coolant again i was wondering what the best mix is for a hot climate. Around here, especially with a black interior and a/c that is not currently functioning, every 10 degrees that the coolant temp rises makes a big difference inside the cockpit. Also could you give these numbers in reference to actual amounts needed to fill the coolant system instead of a percentage ratio, as i am not sure how much the system holds or how much water from the flush will still be in the block when i fill it up again.
Thanks in advance
Wheelman is offline   Reply With Quote
Old 07-06-2003, 01:44 AM   #2
weekendwrench
CF Senior Member
Default Re: Whats the best coolant mix for a very hot climate?? (Wheelman)
I would use distilled water and "Water Wetter". Use about 10% antifreeze just for the anti corrosive properties. Switch back to a 50 /50 mix in winter if you live where it freezes.
weekendwrench is offline   Reply With Quote
Old 07-06-2003, 02:46 AM   #3
Wheelman
CF Senior Member
Wheelman's Avatar
dkredmetallicc4
Default Re: Whats the best coolant mix for a very hot climate?? (weekendwrench)
will using less antifreeze and more water make your car cooler or am i just guessing??
[Modified by Wheelman, 1:46 AM 7/6/2003]
Old 07-06-2003, 08:47 AM   #4
vader86
CF Senior Member
vader86's Avatar
Yeah, the water is better at cooling than antifreeze is, and water wetter works best when used with straight water.
You just cant use tap water, and you should put just a little antifreeze in.
And dont run straight water in winter, Id still run 60/40 water/freeze in winter at least.
[Modified by vader86, 8:49 AM 7/6/2003]
vader86 is offline   Reply With Quote
Old 07-06-2003, 11:29 PM   #5
black_89_vette
CF Senior Member
black_89_vette's Avatar
Default Re: Whats the best coolant mix for a very hot climate?? (vader86)
I am running distilled water and a bottle of 40 Below. It's kind of like Water Wetter from what I've read on it.
I was having some serious overheating issues (aux fan went also), and having replaced the fan motor, flushed rad and topped it up with the distilled water and the 40 Below, it really keeps it cool.
It's like a new car, 175-180 highway, 180-192 in town.
black_89_vette is offline   Reply With Quote
Old 07-06-2003, 11:55 PM   #6
Dan Parker '96
CF Senior Member
Weekendwrench has it right... The thing to remember is to add a corrosion inhibitor package to the distilled water. That is imperative!
But you should witness about 20% better cooling efficiency with straight water.
I refer you to this link for a short but informative article... http://www.caranddriver.com/article....&page_number=1
Dan Parker '96 is offline   Reply With Quote
Old 07-07-2003, 01:05 PM   #7
sundbergjc
CF Senior Member
Default Re: Whats the best coolant mix for a very hot climate?? (Dan Parker '96)
Another inexpensive item that helps is a 160 thermostat (stock is 180). I just put one in my 95 LT1 and my normal running temp came down 25 degrees (in Alabama summer). On the surface this would appear to not make sense, but I think the 160 flows a little more volume.
sundbergjc is offline   Reply With Quote
Old 07-07-2003, 01:17 PM   #8
John Row
CF Senior Member
John Row's Avatar
The above posts are correct, but I wouldn't go much below a 70/30 mix for any length of time. You really need the properties of the antifreeze to fight corrosion and lubricate the pump.
John Row is offline   Reply With Quote
Old 07-07-2003, 02:18 PM   #9
kittmaster
CF Senior Member
kittmaster's Avatar
Send a message via AIM to kittmaster
Default Re: Whats the best coolant mix for a very hot climate?? (John Row)
:iagree:
Expect a shorter pump life if you don't have enought antifreeze in there....
kittmaster is offline   Reply With Quote
Old 07-07-2003, 03:57 PM   #10
pwrful c4
CF Senior Member
pwrful c4's Avatar
Send a message via AIM to pwrful c4
:iagree: :iagree:
pwrful c4 is offline   Reply With Quote
Old 07-07-2003, 04:29 PM   #11
ROADAPPLE
CF Senior Member
ROADAPPLE's Avatar
Default Re: Whats the best coolant mix for a very hot climate?? (black_89_vette)
90% distilled water, 10% anti-freeze, 2 bottles of Redline Water Wetter.
ROADAPPLE is offline   Reply With Quote
Old 07-12-2003, 04:37 PM   #12
tkrussell
CF Senior Member
tkrussell's Avatar
Default Re: Whats the best coolant mix for a very hot climate?? (C44ever)
Another point to consider is whether you use A/C. With the A/C on Max or Recirc the heater core will be exposed to Freezing air, and coolant flow to the core will be shut off. Best to have enough antifreeze in the mix to cover down to 28 degrees or so. 10% antifreeze protects to 25 degrees.
The Redline site (www.redline.com) has a nice discussion of this topic.
tkrussell is offline   Reply With Quote
Old 07-12-2003, 10:24 PM   #13
oldace84
CF Senior Member
St. Jude Donor '04 & '05
oldace84's Avatar
Wheelman'
sorry, but :confused: :confused: :confused:
thanks
tony
:steering:
oldace84 is offline   Reply With Quote
Reload this Page Whats the best coolant mix for a very hot climate??
Tags
antifreeze, climate, climates, coolant, coolants, distilled, engine, hot, hotter, mix, radiator, summer, warm, water, wheather
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
