Dash lighting wire for aftermarket gauges???
Old 07-01-2003, 03:52 PM
vvv90
vvv90's Avatar
Default Dash lighting wire for aftermarket gauges???
The white and black wires that come off the back. What's the best way to attach to the dash light?
Also my Fuel pressure gauge requires a hookup to the ignition somehow. Any help is appreciated!
:cheers:
Old 07-01-2003, 04:25 PM
1989redvette
1989redvette's Avatar
Default Re: Dash lighting wire for aftermarket gauges??? (vvv90)
the best way is to find the out wire from your headlight/park light switch that runs to the dash lights...you can do this by using either a wiring diagram or a test light.. if ya use a test light just find the wire that gets controled by the reastat that works the rest of the dash lights.it should make the test light bulb go form bright to dim by turning the headlight switch **** just like your dash lights ..by hooking up this way you can have your gauge lights the same brightness as your dash lights... :cheers:
Quick Reply: Dash lighting wire for aftermarket gauges???
