What now? Hissing noise. (Brakes)
Was driving along earlier today and the brake pedal got hard and the brakes got to the point I really had to push to get the car stopped. :mad :mad The brakes still work, but I believe my vacuum booster has bit the dust. Now, everytime I step on the brakes I get this hissing sound coming from under the dash and the pedal is as hard as a rock. I have to press as hard as I can just to stop the car.
First: To anyone else that's had this problem, does this sound like the vacuum booster?
Second: I've already priced the part, for those of you that have replaced it yourself, how difficult was it and can you give me some tips as to how to do it?
Thanks.
Thanks.
Re: What now? Hissing noise. (R94 LT 1)
Do you check the vacuum hose that goes to the booster? That was my problem, the hose was old and wasn't making a tight seal, so I just put a hose clamp on it and no more problem. Quick and easy to check before you fork out the dough for a new booster. :thumbs:
Re: What now? Hissing noise. (VetBoy89)
Sounds like the diaphram in the booster has failed. I haven't changed one but I would think about maybe pulling the seat just so you can see your way around underneather there.
[Modified by ittlfly, 12:38 PM 6/27/2003]
Re: What now? Hissing noise. (ittlfly)
If I have to get in there the seat will HAVE to come out! 6'3", I take the seat out for any work under the dash! :D Rest my feet over the ledge in the back.
Sounds like the booster, use a 1/4 inch ratchet with a long extension and a wobbly 13mm, or maybe it was a 12, to get to the nuts inside. To put them back on the reinstall, wedge a piece of paper or some tape around the nut, and it will stay in the socket, till you get it started. Not to bad, but I was upside down for a while. :cheers:
Re: What now? Hissing noise. (buzzbomb)
Everyone feel free to add. The more info the better. :yesnod:
It's the brake booster... happened to me 3 months ago..identical symptoms...good luck
Re: What now? Hissing noise. (Fuzzy Dice)
Try sitting on the ground outside the car. That's the way I did mine. Wasn't upside down, or laying on my back. I just sat on the ground and leaned in.
Anyway, it's not hard. Took me about 2.5hrs total and I had to adjust the pushrod length several times to get the correct pedal height and feel. Good luck :cheers:
Re: What now? Hissing noise. (JCAIRE2)
Update. Including cleaning up the area real well (as I've tried to detail everything else underhood) the new booster was in in about 3 hours or so. All is well. :yesnod: Thanks to everyone for the tips and info. :cheers:
