center console lock, hatch open button
Old 06-08-2003, 12:12 AM
kwd1
kwd1's Avatar
Default center console lock, hatch open button
Anyone have trouble locking their center console.
Mine wont lock. The latch doesn't clear the part of the console lid it's
supposed to latch to. It's off about 1/16".
I'm trying to lock it because I run with the targa off a lot and I 'discovered' that
you can reach in, open the console, press the hatch button, and the hatch opens.
Alarm goes off, but you would be just seconds from having a new targa top.
Old 06-08-2003, 12:22 AM
jackdaroofer
Support Corvetteforum!
jackdaroofer's Avatar
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: center console lock, hatch open button (kwd1)
:cheers:
Not sure I am on the right track, but often, heat and time warp the console lids.
Have you tried applying gentle pressure to line it up as you lock it?
One other solution might be to disable the switch
:seeya
:steering:
Old 06-08-2003, 12:24 AM
65Z01
65Z01's Avatar
I don't know if the lock is adjustable but the latch tab position is adjustable by loosening the two retaining screws.
Can it be reached with the windows up?
Old 06-08-2003, 03:29 AM
Irishpilot03
Irishpilot03's Avatar
Default Re: center console lock, hatch open button (65Z01)
My console lid is also a little warped, so I have to put elbow pressure on top to get it to lock. If you're worried about the latch button, all you have to od is unbolt the shifter console plate and unplug two detachable wires and you will have a non-functional button!
To center console lock, hatch open button
Quick Reply: center console lock, hatch open button
