lt1 race block?
Old 05-20-2003, 10:08 AM
RedyGo
RedyGo's Avatar
Default lt1 race block?
tpis told me they built an lt1 with a 4.1" bore, using a gm race block. does anybody know anything about this block?
Old 05-20-2003, 11:00 AM
buell_freak
buell_freak's Avatar
Default Re: lt1 race block? (RedyGo)
I do not know all of the details, but have also heard of this being done by some racers. Check with Trevor at "Exotic Muscle" in Tempe AZ..... I think he has done this if not he is very up on what every one is doing and why.
Old 05-20-2003, 11:32 AM
Zix
Zix's Avatar
I've heard of these blocks, but from what I've been told they are virtually impossible to find. I know of one right now, but there is no way you can get it from the guy that owns it for good reasons on his part.
Old 05-20-2003, 11:57 AM
Ramrod92
Ramrod92's Avatar
Cruise-In II Veteran
Looks like that would only give you 409 cubic inches with a 3.875 stroke crank. $$$$$$$$$ :steering:
Old 05-20-2003, 12:05 PM
rcdk
rcdk's Avatar
How different are the different generation blocks?
Given the number of LT1s out there, I would think there would be a significant market for a big bore second generation small block.
Old 05-20-2003, 10:41 PM
bogus
bogus's Avatar
Default Re: lt1 race block? (rcdk)
The LT1 is a seriously different... The Gen 1 heads will not fit on the Gen II block... the flow of the coolant is reversed... the ignition, technially, is different, but the engine will support a conventional distributor.
To lt1 race block?
Quick Reply: lt1 race block?
