Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-17-2003, 05:54 PM   #1
TheCorvetteKid
CF Senior Member
TheCorvetteKid's Avatar
Default What are the symptoms of bad ignition timing?
What kind of performance/operation would I experience from my engine ('89 L98) if my ignition timing where off (either advanced or retarded)?
Thanks in advance.
TheCorvetteKid is offline   Reply With Quote
Old 05-17-2003, 06:49 PM   #2
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
Default Re: What are the symptoms of bad ignition timing? (TheCorvetteKid)
With optimum timing trap speed will be highest, from peak hp.
If timing is too advanced ping and timing retardation will result, as can be seen on a scan tool.
If timing is too retarded throttle response will suffer as well as peak hp.
65Z01 is online now   Reply With Quote
Old 05-17-2003, 07:47 PM   #3
jackdaroofer
CF Senior Member
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Support Corvetteforum!
jackdaroofer's Avatar
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
Default Re: What are the symptoms of bad ignition timing? (65Z01)
:D I would add "hard to start when hot"
:seeya
jackdaroofer is offline   Reply With Quote
Old 05-17-2003, 09:28 PM   #4
CarAteMyMoney
CF Senior Member
CarAteMyMoney's Avatar
Send a message via AIM to CarAteMyMoney
Default Re: What are the symptoms of bad ignition timing? (jackdaroofer)
speaking of timing, what/where is the wire that you have to unplug to get an accurate reading with a timing gun?
it should be 8 degrees on a stock motor, correct?
CarAteMyMoney is offline   Reply With Quote
Old 05-17-2003, 11:18 PM   #5
vader86
CF Senior Member
vader86's Avatar
:withstupid:
And the stock setting is 6*, but the L98 likes it a little advanced so i run 8*
vader86 is offline   Reply With Quote
Old 05-18-2003, 12:30 AM   #6
Mach85
CF Senior Member
Mach85's Avatar
Default Re: What are the symptoms of bad ignition timing? (vader86)
I thought it was 6. I also had a popping (backfire) from timing being off. Now I have a slight hesitation when hitting the gas, my timing is off a little I did it by ear to get it close. I let someone borrow my timing light and haven't seen it since.
Mach85 is offline   Reply With Quote
Old 05-18-2003, 07:56 AM   #7
rodj
CF Senior Member
rodj's Avatar
Default Re: What are the symptoms of bad ignition timing? (CarAteMyMoney)
The wire to disconnect is located beside/ behind the dist on the passengers side.One of those weatherproof connectors that looks like an inline fuse holder.Tan with black stripe from memory.
rodj is offline   Reply With Quote
Reload this Page What are the symptoms of bad ignition timing?
Tags
89, advanced, bab, bad, c4, corvette, effects, engine, ignition, retarded, shine, signs, symptoms, timing, timingsymptoms
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
