Just did the TB bypass mod.
And on the '95 it was very easy. No extra parts needed at all. (except for one beer). :cheers: I simply unclamped the two in-out coolant lines from the tb, towel-caught as much of the extra coolant pee as I could, discarded the short elbow hose (which I'm not sure was either the 'in' or 'out' line) (passenger side) that
goes into the solid line that then goes to the heater (aparently). Then I simply took the other line (drivers side) which ran out the top of the radiator, re-routed it and clamped it right to that solid passenger side line. Easy. No cutting, no parts, and only a few cuss words. Twenty minutes well spent.
Thanks goes to this site and all of you.
[Modified by BlackBeast2, 2:37 PM 5/5/2003]
Re: Just did the TB bypass mod. (marlon88)
:cheers:
1 Post
Cruise-In III Veteran
Cruise-In IV Veteran
Re: Just did the TB bypass mod. (radwebster)
did you feel a noticable difference? thanks :)
Location: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
1 Post
Re: Just did the TB bypass mod. (BlackBeast2)
Agree, every horsepower counts, especially when they are free!
Re: Just did the TB bypass mod. (LT-4 CE)
well, why did they route the coolant through there in the first place? GM must've had a reason, otherwise they would've taken the free horsepower too.
Same way I did mine. I also used a plastic tie-down strap to hold the TB bypass line to the water pump hose because I found that it tended to press upwards against the IAT sensor and cause the IAT sensor to want to rotate out of its forward position.
Consequently, the hot coolant passing through heats up the air intake charge thereby hurting horsepower.
Do your car a favor and do the bypass.
:chevy
[Modified by BlackBeast2, 5:33 PM 5/6/2003]
Re: Just did the TB bypass mod. (Lone Ranger)
St. Jude Donor '05
I did mine and forgot to rehook the idle control. I restarted the car and it wouldn't come off a 1200 rpm idle. After a couple of minutes and a trip to the garage fridge I figured it out.
