steering fluid
steering fluid
hi,
i have a 92 lt1 zo7 6 speed i bought used with 85,000 miles on the clock, this weekend i'm going to be doing some underhood cleaning (not using water though) and was wondering if i should change the power steering fluid or not to my knowledge it has never been changed and the car is 100% stock, there are no steering problems with the car just wondering if its something i should do if so should i use redlines synthetic power steering fluid and how much would it take.
thanks :flag
thanks :flag
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: steering fluid (sfields1)
:cheers:
hanging to new fluids generally never hurts anything...synthetic power steering fluid is a definite improvement over dino. Synthetic handles the heat ranges better.
I use Amzoil auto tranny fluid
:steering:
:steering:
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
Re: steering fluid (golfboy1)
:cheers:
:D Yes :D
I have had it in there 5 years now, no sign of "morning sicknes", no leaks!
:seeya at CI4
:steering:
:D Yes :D
:seeya at CI4
:steering:
What ever happened to the days when power steering fluid was red and you could tell if your leak was oil or power steering fluid?
Re: steering fluid (Strick)
:leaving: Those day's are over.
Location: And on the fifth day, subpoenas were served to Obama senior staff
1 Post
Re: steering fluid (jackdaroofer)
Use GM "Cold Climate" power steering fluid. It's better to use a PS mix as it contains the additives required to properly protect the PS system. GM cold climate mix is not just for cold climates. It's a nice semi synthetic mix with the "right stuff" for your PS system. Trust me on this. I buy it by the case from Jeff Koop.
I know what you are saying Jack, but this stuff is really good.
Pete
:cool:
