86L-98 Firing order?
1 Post
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
Re: 86L-98 Firing order? (CLUTCH^Master)
turns out i need another combo, can someone help :banghead:
The distributor cap has a square section on the drivers side where the power/tach wires plug in. the # 1 plug wire needs to be plugged in to the second "post" in a clockwise rotation from this square block. This is the # 1 spark plug location. One off in either direction will cause the car to do what you described above.
The square block should end up between #7 & #2.
[Modified by severe-1, 12:06 AM 3/29/2003]
Re: 86L-98 Firing order? (severe-1)
well those wires are where they need to be but my problem could be that i'm refering to a camaro manual and and i don't know if its the same firing order as mine. :confused:
ok it kinda runs for a millisecond and dies, i rev it it dies, the firing order is in as you all stated. it shoots up a service engine code. any ideas on what i did wrong?
(from the begining) my car had a miss fire in it. i the changed the fuel filter and it made it a little better but the miss remained. so today i replaced the cap and rotor and it got a little worse. then i began listening to differant web sites and i changed my firing oder 5 times and tryed to start the car. a couple of times the car would start but the car would miss even worse. so now we went back and followed the maunal and now the car will turn on the die right away and i don't know if i messed up the timing or what. :banghead:
Unless you turned the distributor, you did not change the timing...
Pull the cap again and double check everything. Also check the coil and the connections to it.
Re: 86L-98 Firing order? (Wheelman)
ok i just finished puting it back exactly as it was before i did anything to it? It still will not run. I was a litle low on gas so i added 5 more gallons, still not runing? what the hell. its just those 3 brackets and bolting the thing down! I am rely geting frusterated
