About half way through my '88C4 to C5 brake conversion
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers:
Tonight I got the right side lined up and "temporarily" installed.
Lining everything up and getting the right size bolts has been a bear.
Tomorrow AM I will do a "permanent" right side install and do the left side too. Then I'll bleed it and take it down the road for a SMOKE and SCRUNCH Test.
Smoke if everything isn't lined up right and ...Scrunch if the brakes don't work :D :D
I went the cheapo route, accumulating everything on E Bay or through friends. So it has taken a little time and effort to run down all the parts.
If it works, I am ahead, since I have less than $ 400 invested....if it doesn't work, ...check out C4 Parts For Sale :D
:steering:
[Modified by jackdaroofer, 8:59 PM 3/28/2003]
:steering:
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
Re: About half way through my '88C4 to C5 brake conversion (jackdaroofer)
:cheers: :D :D :D
Got it all done Saturday AM and took the test!
Awesome! If you like driving your car with " Vim and Vigor" I recommend this as one of the best mods you can do.
This winter I have installed 30mm front, 24mm rear sway bars, C5 front brakes and the DRM brake bias spring.
Ready for spring and summer road trips now!
:steering: [ I love that Lil Guy ]
[Modified by jackdaroofer, 7:05 PM 3/30/2003]
What C5 Capiler adapter brackets did you use? Also where did you get them?
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
Re: About half way through my '88C4 to C5 brake conversion (-=Jeff=-)
I bought the caliper brackets themselves as well as C5 hardware from Jeff Kopp. I bought the calipers and roters (like new) on E Bay
:steering:
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
Re: About half way through my '88C4 to C5 brake conversion (ZAD54)
I've been wanting to do this to my '88 also. Did it make a big difference in your handling and where did you find the sway bars? :cheers:
I got the sway bars and all the bushings from Jeff Kopp at
http://www.superiorperformancechevy.com
Very good prices, much less than the "catalog" stores
:steering: [ I love that Lil Guy! ]
[Modified by jackdaroofer, 8:09 PM 3/31/2003]
anytime! I like to watch others projects... it inspires me to do more!!!
:thumbs:
:thumbs:
