What are the best suspension mods to do?
I was wondering what are the best suspension mods to do to our cars to stiffen up the ride and make for better handling? I have a 1995 Vette 6-speed. Thanks
Received 1,400 Likes
Re: What are the best suspension mods to do? (yellowc4LH)
Z51 springs, bigger sway bars, poly bushings, stiffer shocks
Re: What are the best suspension mods to do? (bill mcdonald)
Re: What are the best suspension mods to do? (89 Paul in Cal)
poly bushings and...............
CAMBER-BRACE from RD Racing!
:cheers:
:cheers:
Also, check out their Cross-Bar and Cross Frame. Bigger sway bar would help reduce some of the body roll also. http://www.r-dracing.com :thumbs:
Cruise-In II Veteran
Lowering it will help and a little more camber will aid cornering.
If you're not drag racing install poly graphite sway bar bushings; otherwise go with larger sway bars.
First, what suspension do you have now? I assume 'base' FE1? Second, what do you intend to do with it? :confused: Autocross? :steering: Road course / time trials? Or? Tell us what your goals are, and we can give some advice on how to move in that direction.
Re: What are the best suspension mods to do? (NavyVet)
I'm also curious about this. I have a '88 Z52 and was wondering if I could just upgrade to Z51 springs and sway bars and achieve a better handling car. It already has poly bushings and a camber brace. Didn't mean to hijack the post, just wanted to ask. :cheers:
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: What are the best suspension mods to do? (ZAD54)
Assuming I am wrong, you might find a nice, inexpensive up grade is Sway bars, 30mm fronts and 24mm rears, also use the Z51 shocks.
:steering:
Re: What are the best suspension mods to do? (jackdaroofer)
Camber Brace and possibly a camber brace. If you decide on something else, like say, a camber brace, then you should consider looking into a camber brace.
Are you sure you don't have the Z 51 already? My understanding and I am probably wrong is the Z52 was VERTs only. Again, I am probably wrong, but i didn't think the add on camber brace would fit a Z52 or Z51 because they already have the extra cross braces in the front of the frame
Well thanks for all the replies. I installed the bigger sway bars and the blistein sport shocks from Ecklers. It handles a lot better. What else do ya'll reccomend? I just drive the car on the street. I just want the best handling i can get. Not real real stiff but really good handling. Thanks
If you're only interested in good handling for the street (fast run on a country or mountain road type fun), alignment is big.
Also, do you still have (assuming you have base suspension) the 8.5 wheels on the front? If so, going to 9.5s at all four corners with 275/40x17s all the way around will improve handling too. I am not talking about straight line driving, but "handling."
Alignment for street with better overall (sporty) handling (and these will not result in significantly reduced tire wear):
Front - camber -0.5 to -0.7 each side (both the same)
toe = zero
caster - 6-7
Rear - camber -0.3 to -0.5 each side (both the same)
toe = 3/32 IN each side
What size bars did you install? If you went 30mm front, 24mm rear would probably be good. Bigger in the rear may increase oversteer tendency.
Try changing one thing at a time and evaluating the results. Good luck.
[Modified by NavyVet, 3:17 PM 3/26/2003]
toe = zero
caster - 6-7
Re: What are the best suspension mods to do? (Fastguy)
I am a firm believer that heim-jointed camber rods for the rear is the best dollar for dollar suspension upgrade for a C4. These eliminate loss of rear wheel camber during hard cornering. The more cornering force you apply to the stock camber rods and bushings the more deflection and loss of camber you will have just when you need it the most. If you look at the size of these bushings and the potential for deflection, it is easy to see how much the heim jointed rods will help. You can change them to poly, but IMO why not change to the rod ends and eliminate all of the deflection and have a better, more precise way of setting the rear camber? As long as the rod ends are properly aligned to prevent them from binding, you shouldn't have any problem with them and it won't affect the ride quality like many other suspension mods will.
What size bars did you install? If you went 30mm front, 24mm rear would probably be good. Bigger in the rear may increase understeer tendency.
Matthew
Re: What are the best suspension mods to do? (AZ_Matt)
Matt - THANKS! I was writing in a hurry and got front-and-rear reversed :eek: I really do know the difference of the two ends of the car - just type without proof-reading sometimes. Thanks again.....Paul
