Where do you buy your distilled water?
Cruise-In V Veteran
Looking to finish up my engine for its first start-up and I want to put distilled water with anti freeze in the radiator. Where do you buy the distilled water and how many gallons do you buy?
Thanks in advance for your comments.
Jim
Jim
Re: Where do you buy your distilled water? (85vet)
Go to any grocery store or discount store. In gal or 2.5 gal jugs. Buy enough to mix 50/50
[Modified by sumoboy, 1:04 AM 3/18/2003]
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Where do you buy your distilled water? (sumoboy)
I will soon be auctioning distilled water on E Bay!
Check it out!
:reddevil :reddevil
Cruise-In V Veteran
Re: Where do you buy your distilled water? (jackdaroofer)
You have given me a great idea! :D
Check it out!
:reddevil :reddevil
Check it out!
:reddevil :reddevil
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Picked mine up at the local grocery store (about seven gallons-just in case).
Evian is a very popular brand. A clear plastic hose is used, instead of a garden hose, to fill the bottles from the tap. Since it has a French name, you might want to carry it home in a brown paper bag......
Re: Where do you buy your distilled water? (Oldman)
:lolg:
Distilled water is pure water. No minerals or nutrients or other chemicals.
:thumbs:
St. Jude Donor '04 & '05
Yep...do use distilled water.....gosh...really available at any store where you shop....I buy a case of the 1 gallon bottles.....OK....
tony
:smash:
tony
:smash:
Re: Where do you buy your distilled water? (Black96Corvette)
It can't make that much of a difference can it? from normal h20
[Modified by MrNuke, 11:40 PM 3/17/2003]
any grocery store should have it. Like others have said, its mineral free and the only water that goes in my corvette.
50/50 in the winter and 70/30 in the summer (water/green antifreeze)
Re: Where do you buy your distilled water? (fourthgencorvette)
I'm surprised the big catalogs haven't tried to screw people over yet...
"Corvette Distilled Water! $5/gallon..." :rolleyes: :jester
Re: Where do you buy your distilled water? (MrNuke)
Actually prevents the white crap that plugs everything up, especially on aluminum radiators. White crap is the minerals that bind up with the aluminum.
Re: Where do you buy your distilled water? (mash557)
The same kind of white crap that winds up on your faucets at home. Try to scrape that from inside you engine. :D :thumbs:
[Modified by sumoboy, 10:08 PM 3/18/2003]
I use only GM factory distilled water. My dealer says because I am such a good customer he will sell it to me at cost, only $4 per gallon. They have their supply tank hooked up directly to the facet. Who says all dealers are crooks?
