1991 Convertible - Oil Temp Sensor Problems
Old 03-13-2003, 08:57 PM
Tony Franco
3rd Gear
Tony Franco's Avatar
Default 1991 Convertible - Oil Temp Sensor Problems
OK -- Who can solve this mystery? Went to the GM Manual, replaced oil temp sensor, checked circuits according to manual. All is OK. Grounded out Oil Temp Gage and it works too...pins all the way up to 320. Checked continuity on connector (3 spade tip) as well. All is OK. Gage never goes anywhere even after running for 1/2 hour. WTF??? :smash: :smash: I'm sure the old sensor was good too!
Old 03-13-2003, 10:16 PM
robertpel9
robertpel9's Avatar
Default Re: 1991 Convertible - Oil Temp Sensor Problems (Tony Franco)
i have a 91 vert too and my temp needle barely ever moves either. My oil pressure needale also is pinned to the max 90 % of the time and flutters the rest. There is a TSB out on this. It's not important to me so i just leave it be.
Old 03-14-2003, 10:01 AM
Rizcoms91
Rizcoms91's Avatar
Gotta tellya. I was getting ready to tackle the same thing! 91 vert and the darn thing doesn't seem to move. What's up with that? :confused: :steering:
Old 03-14-2003, 11:25 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
The oil temp sw is just a thermister like the coolant temp sw.
If the +5Vdc and ground are good and connecting the feedback pin to either ground or +5Vdc pegs the reading the connection to the ECM is OK, so the problem must be in the sensor.
Old 03-14-2003, 12:34 PM
robertpel9
robertpel9's Avatar
Default Re: 1991 Convertible - Oil Temp Sensor Problems (65Z01)
I've replaced the sensor and nothing changed. I dont even think about it anymore. Just make sure you are changing the oil as required and that it is at the right fill level. If a real problem develops it will show up in the collant temp first anyway. At this point i don't even notice mine and my engine runs like new and used no oil between changes.
To 1991 Convertible - Oil Temp Sensor Problems
Quick Reply: 1991 Convertible - Oil Temp Sensor Problems
