Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-27-2003, 10:21 AM   #1
wccavette
Junior Member
Default C4 Headlight motor removal
How do you remove the headlight motor from the brackets in order to replace the gear drive? This piece was not designed with maintenance in mind!
wccavette is offline   Reply With Quote
Old 02-27-2003, 02:40 PM   #2
Steel Blue 91
CF Senior Member
Steel Blue 91's Avatar
Default Re: C4 Headlight motor removal (wccavette)
Sorry, don't have the manual at work and am smart enough not to trust my memory on some things, but here is a bump to the top for ya.
BTW welcome.
[Modified by Steel Blue 91, 2:42 PM 2/27/2003]
Steel Blue 91 is offline   Reply With Quote
Old 02-27-2003, 02:45 PM   #3
VetBoy89
CF Senior Member
VetBoy89's Avatar
Hey welcome to the Forum!!! :cheers: :seeya :thumbs:
Check out this tech tip, it should help you out, it's the one I used when I did my bushings.
[p] http://corvetteforum.com/techtips/vi...D=16&TopicID=2
:thumbs:
[Modified by VetBoy89, 11:46 AM 2/27/2003]
VetBoy89 is offline   Reply With Quote
Old 02-27-2003, 02:46 PM   #4
jimswhite92
CF Senior Member
jimswhite92's Avatar
Send a message via AIM to jimswhite92
This is from the tech tip section. Hope it helps. Also you can search recent topics on this subject. It has been on this forum a lot in the past.
jimswhite92 is offline   Reply With Quote
Old 02-27-2003, 02:54 PM   #5
brdd
CF Senior Member
Support Corvetteforum!
brdd's Avatar
Default Re: C4 Headlight motor removal (jimswhite92)
:iagree:
I did this last summer. It took me 2 hours for both sides and I work slowly. I think the cost for the delrin bushings was $10 for both sides. Be careful not to break off the little screws holding the gear housing cover on. I had to drill and tap two of them out. Clean out the dust from the old bushings. This is an easy fix relative to some corvette projects. Take your time and you will be rewarded with lights that open and close like new! :thumbs:
Bob, I almost forgot.......welcome to the forum! :seeya
[Modified by brdd, 1:55 PM 2/27/2003]
brdd is offline   Reply With Quote
Old 02-27-2003, 09:19 PM   #6
Invanity
CF Senior Member
St. Jude Donor '05-'06
Invanity's Avatar
Send a message via Yahoo to Invanity
I've got to replace the right headlight gears in my 87...What I'm going to use is last months Vette mag. They had an article there with plenty of pics to show you how to do this. I'll be expecting the gears tomorrow from Ecklers...Cant wait to have use of those headlights again, I hate having to open the hood just for that :U
Invanity is offline   Reply With Quote
Old 02-28-2003, 03:20 AM   #7
65Z01
CF Senior Member
Cruise-In II Veteran
65Z01's Avatar
Send a message via AIM to 65Z01
I used a hex ball driver to access the two Torx bolts on the frame under some other hardware.
You may need a drift to remove the drift pin holding the drive to the shaft.
65Z01 is online now   Reply With Quote
Reload this Page C4 Headlight motor removal
Tags
c4, corvette, head, headlamp, headlight, light, motor, removal, remove, removel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Headlight Door Motor Question Amazing1 C4 General Discussion 11 10-04-2004 11:12 AM
101 projects for your 1984-1996 Corvette! Kizmo C4 Tech/Performance 22 03-04-2004 12:27 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
