Bolts or studs?
Old 09-16-2013, 09:50 PM
87bob
87bob's Avatar
Default Bolts or studs?
Building a stroker should I go the distance for the studs over factory bolts?
Old 09-17-2013, 12:01 AM
mtwoolford
mtwoolford's Avatar
studs, if designed to mount a windage tray, offer a range of adjustability which might be a needed with a longer stroke crank.
Old 09-17-2013, 12:31 AM
Deakins
Deakins's Avatar
Are we talking for the main caps, head bolts, oil pan, or valve covers here? Or all? If they are in the budget fine, if not I wouldn't sacrifice quality parts for them on an engine that will not be getting torn down a lot. Just my .02
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
If you're talking about studs for the heads, I don't believe the heads will clear the power brake booster if studs are used. Bummer to have to pull the motor to remove a head.
Old 09-17-2013, 05:26 AM
93 ragtop
93 ragtop's Avatar
Just use ARP bolts for the heads.
Old 09-17-2013, 06:26 AM
hemivett
hemivett's Avatar
Same here. ARP bolts are good to like 200,000lbs. Technically studs are ment for racing engines, that are being constantly taken apart. If you use ARP bolts, you'll never have to worry about it, till the cam is flat, and she's blowing smoke. Even then you could still reuse them, since the aren't torque to yield bolts like the factory pieces. h
Old 09-17-2013, 11:29 PM
84wannabezo6
84wannabezo6's Avatar
My machinist said that using studs for the 4 bolt main block Im using would need align bore but with the arp bolts not necessarily.
To Bolts or studs?
Quick Reply: Bolts or studs?
