Changing a turn signal stick???
Does anyone know what I have to do to remove my turn signal stick on my steering column??? There doesn't seem to be an easy way to pull the plastic covering off to change it. Yes I broke it somehow and now the right turn signal won't click. I can feel something physical broke inside the mechanism. Thanks.
Re: Changing a turn signal stick??? (mn_vette)
Sounds like the ring that goes around the steering wheel broke.
I hate to tell you, but you are going to have topull the steering wheel to get to it.
I don't know the procedure for your year with an Air bag, but once you get that disconnected it is not that bad.
Re: Changing a turn signal stick??? (-=Jeff=-)
I've pulled the airbag before, that's not that big of a deal, is there any special tools I need to pull the steering wheel off??? I have a feeling this is going to be a pain :mad
Also, a retaining ring tool, it's about $5-$15 at any auto parts store. You MAY be able to compress the spring with c-clamps etc., but don't bother, you will make your life miserable.
Most likely the "ear" molded into your "pulse and pivot assembly" is broken off, this is what's causing your problem. Somewhere b/w $100 and $200 for the part.
Re: Changing a turn signal stick??? (Vince Ivanc)
Also I *MAY* have a turn signal ring assembly in good shape if interested, I will need to look for it though
1 Post
St. Jude Contributor
I just did this fix on my '92, believe me it's a real PITA. . . . . If I had it to do over again, I'd pay the shop the $250-$300 to do it. Me and another experienced vette wrencher worked most of two days on it. But to answer your post, the plastic housing behind the "stick" just pops off, then the stick pulls out, no hardware. What year are you working on?
[Modified by edsalinas, 1:15 PM 2/22/2003]
[Modified by edsalinas, 1:17 PM 2/22/2003]
Re: Changing a turn signal stick??? (edsalinas)
Trouble is, if the turn signal switch won't stay clicked in place, it's the whole darn switch mechanism behind the steering wheel, airbag coil, lock plate, etc.
After you pop off the column cover and disconnect the cruise control connector, the actual stick just pulls right out of the column, POP!. But the switch mechanism is a collar that wraps around the shaft, with a huge cable bundle that runs through the column down to another connector bank.
To replace the turn signal switch you pretty much have to at least pull the wheel and coil, and drop the steering column.
I'm replacing my column right now. Took this picture this morning.
[Modified by Matt Black, 2:19 PM 2/22/2003]
1 Post
Re: Changing a turn signal stick??? (Matt Black)
Yeapppppppppp , , , , , , , watch out for that round snap ring that you have to depress the lock ring to get at ! ! ! ! :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash:
1 Post
Re: Changing a turn signal stick??? (RX7 KLR)
Man, I wont do it again, and I do alot of work myself. We spent the better part of two hours just threading the new harness down thru the column, it kept hanging up on different crap . . . . . .
:reddevil :cuss :reddevil :cuss :reddevil :cuss :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
It happened to me too, on my 93. if you look through the little gap where the turn signal switch goes into the column you can see the little plastic ear that makes the signals click. Mine was broken. i used needle nose pliers and through that hole i super glued it back on. I waited 5 days before i drove it and it works fine, but im careful not too press too hard.. either way im replacing it as im typing. I sent it to get rebuilt. :cheers:
Re: Changing a turn signal stick??? (BLU_VT)
This happened to me on my 92, the stick was just flopping back and forth when I tried to put the brights on. I pulled the wheel to get to it and never could fix it. Finally took it to the dealership and they fixed it. Cost me $300 for 25 cent part :mad Anyway, the problem was way further down in the column and not in the signal itself.
Yikes..... :eek: Took 15 minutes to change the one in my 89'.... I guess thats one + for the old Atari cars. :D
