Does this sound like a good price for a motor?
This motor is 100% assembled and ready to roll (Less Intake/Headers)
Custom Machined 1-piece Rear Main Seal Roller Block 350 Blocked
-Machined .060 over
-Hi-Nodular 3.75 stroker crank
-Eagle H-Beam 5.7" rods
-SRP 16CC dish forged piston
-Speed Pro moly rings (For Nitrous)
-Clevite main & rod bearings
-Application Specific flex plate & damper
-Custom CNC Ported center bolt heads
-Crane energizer rocker arms (1.6 ratio)
-ARP head bolts & complete gasket set
-Cloyles true roller timing set
-TPiS ZZ9 Camshaft
$4850
Does that sound like a good deal??
-Machined .060 over
-TPiS ZZ9 Camshaft
$4850
Re: Does this sound like a good price for a motor? (TIMSPEED)
It's not a bargain but it has some nice pieces. It wouldn't be enough compression for me. Do you know what valves are in the head and flow numbers?
Personally, I'd be concerned about the 0.060" overbore and nodular crank with nitrous (mentioned next to the rings....) Personally, I wouldn't pay that much for a block that has no rebuilds left in it and may be marginal for it's intended purpose, as well as a nodular crank. Now, if it were a 0.030" block w/ a good forged crank, I'd reconsider. I'm not saying that the price isn't right for the components, I just wouldn't drop $5k on a motor that I personally feel won't hold up all that well to abuse.
Re: Does this sound like a good price for a motor? (CorvetteZ51Racer)
check out http://www.allchevyengines.com im sure he will give you a better deal. you can pick a engine & customize it how you like. they let me upgrade alot of things for very little$. :yesnod: :cheers:
Re: Does this sound like a good price for a motor? (yoslambo1@cs.com)
it's not a bad deal by any means, see if the guy has main bearing clearance numbers. the iron crank isn't really a strength concern on a 400-450hp engine, it's setting them up that's harder than the high quality forged units. that engine also could use a little more cam than a zz9. something like my cam would definatly fit the engine a little better. the zz9 is nice if you have emissions however. i'd say, if the engine was built by a high class builder and you get numbers on the build, it's worth buying. if it's a "as-is" deal keep looking.
