Which gas octane is better?
Old 02-16-2003, 02:49 PM
Lord Odin
Lord Odin's Avatar
Default Which gas octane is better?
91, 92, 93 or higher for a stock vette?
Our cars don't have some sort of "knock sensor" to adjust for timing, do they? :confused:
Old 02-16-2003, 02:52 PM
Raistlin
Raistlin's Avatar
Default Re: Which gas octane is better? (Lord Odin)
the lowest octane without degrading performance is best.
our cars have knock sensors which will cut timing by up to 10* when knock is detected.
i use super, 92 or 93, don't remember, because 89 causes ping in my car
edit: probably would be better to say, the lowest octane without inducing knock is best
'90 L98 ZF6
[Modified by Raistlin, 2:54 PM 2/16/2003]
Old 02-16-2003, 03:04 PM
pwrful c4
pwrful c4's Avatar
I always use the highest octane i can get,never under 93. :steering:
Old 02-16-2003, 03:21 PM
vader86
vader86's Avatar
Received 1,398 Likes on 1,015 Posts
Its debateable which octane rating is best for YOUR car, each is different enough that it might not register knock counts with 91-93 octane. But with an LT1, i would be running 92 all the time.
And we all have knock sensors.
Old 02-16-2003, 03:57 PM
Lord Odin
Lord Odin's Avatar
Default Re: Which gas octane is better? (vader86)
I try to run 92 or higher if I can but I was just wondering what a completely stock vette should run with.
Old 02-16-2003, 07:50 PM
vetteweiser
Support Corvetteforum!
vetteweiser's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The book says, use premium. Thats what I do (completely stock, except for LT4 roller rockers). Premium for me is 93 octane.
Old 02-16-2003, 08:00 PM
scorp508
scorp508's Avatar
....but I was just wondering what a completely stock vette should run with.
Whatever octane you can run full throttle and get no pinging.
Old 02-16-2003, 08:07 PM
Dudeurgettnavette
Dudeurgettnavette's Avatar
Default Re: Which gas octane is better? (pwrful c4)
:withstupid:
Old 02-17-2003, 03:04 AM
Darkness
Darkness's Avatar
Default Re: Which gas octane is better? (vetteweiser)
And for me is over $2 now. :rolleyes:
Old 02-17-2003, 03:17 AM
vetteweiser
Cruise-In V Veteran
Default Re: Which gas octane is better? (Darkness)
ouch... I could go off on a tangent, about gas prices, and the fact that we could be paying a lot less now, if certain things were done, but I wont....
I noticed today though, that, 93 has gone up to (in its lowest price, with quality) 1.87/gallon
:mad :mad :mad
Old 02-17-2003, 09:49 AM
robertpel9
robertpel9's Avatar
Premium is 93 octane here. Thats what i use.
Old 02-17-2003, 09:57 AM
c4cruiser
c4cruiser's Avatar
The label on my 92's gas filler trim piece says Premium Fuel Recommended. I have run both 91 and 92 octane with no problem. I did try a mid-range 89 once while on a trip and while the car seemed to run fine, the check engine light came on after about 30 miles of freeway driving. I never checked the code, but it was the only time I got that light after a week on the road. Disconnected the battery to clear everything and no light since.
I'll always use premium!!
Old 02-17-2003, 10:11 AM
joecaver
joecaver's Avatar
Location: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
The highest you can buy is the best.
Old 02-17-2003, 10:38 AM
Steel Blue 91
Steel Blue 91's Avatar
Default Re: Which gas octane is better? (c4cruiser)
The label on my 92's gas filler trim piece says Premium Fuel Recommended. I'll always use premium!!
My 91 has the same recomendation. I use 93 or 92 and have had no issues.
Old 02-17-2003, 12:49 PM
_freakmonkeydogboy_
_freakmonkeydogboy_'s Avatar
Default Re: Which gas octane is better? (Steel Blue 91)
I use 91 or 92 or 93, whichever one they have at the particular gas station i stop at... :D
Old 02-17-2003, 01:30 PM
MagikDraggin
MagikDraggin's Avatar
Cruise-In V Veteran
Quote:
"I always use the highest octane i can get,never under 93"
__________________________________ _ _ _ _____________
The best I can find here at the pump is 91 octane for my stock LT1. It (seems) to run ok.
What I'd like to know is if it is detrimental to run something like the 100 octane unleaded that is available at a couple places? Is there any performance gain in doing this, or is it just a waste of money?
Karl
[Modified by MagikDraggin, 12:32 PM 2/17/2003]
Old 02-17-2003, 01:33 PM
SurfnSun
SurfnSun's Avatar
St. Jude Donor '10
Default Re: Which gas octane is better? (MagikDraggin)
I run a blend of 93 octane and either 114 leaded or 100 unleaded, depending what my intentions are. :D I go with a 60/40 mixture.
To Which gas octane is better?
Old 02-17-2003, 01:51 PM
FELNGR8
FELNGR8's Avatar
I can run on 93 with some knock sense retard at full throttle. It runs MUCH better on Sunoco 94. I'll bet it would give INSANE power on av gas.
These cars will give as much ignition advance as they can stand until they sense knock. They will give more powerr on better stuff. But you can't get the 94 octane everywhere, and for cruising it's not worth $.20 per gallon more. Worth it at the track.
Old 02-17-2003, 02:56 PM
RUSS105
RUSS105's Avatar
Default Re: Which gas octane is better? (94lt1torchred)
:iagree: :D
Old 02-17-2003, 03:26 PM
MagikDraggin
Cruise-In V Veteran
Quote:
"These cars will give as much ignition advance as they can stand until they sense knock. They will give more powerr on better stuff. But you can't get the 94 octane everywhere, and for cruising it's not worth $.20 per gallon more. Worth it at the track."
But what is the limit, where additional octane is nothing more than overkill? Is there some way to calculate what the max octane would be for a given setup, which would be useful for performance?
Like should I use straight 100oct unleaded in my stock LT1 if I'm going to do some serious driving, or would a 50-50 mix (or less) be just as efficient?
Karl
Quick Reply: Which gas octane is better?
