Install shortblock, or w/heads&lower intake
Hello All,
Got an '89 AT. Trans/converter are in car, engines out. Would thing be easier, if we install the short block, get bellhousing bolts in, motor mounts, and everything else, _then_ put both heads, intake on? Or install long block, and lower intake. I'm using ARP head studs. both heads were pulled, and the short block alone was removed (rather painlessly).
I guess I don't really want to torque heads/intake on, while in the car. But, that's what I'm asking here. Is installing the long block, the logical approach? Thanks for listening..
