e-brake cable meets exhaust pipe?
The e-brake cable crosses under the rear between the storage bins and the seat's floor pans. It hangs low enough that I wonder if anyone had issue when installing aftermarket exhaust? Specifically, it's about 1" under the C-beam vs up against it. I not yet to the shop for installation but selecting parts...and measuring...and measuring...and measuring. One config might include a dual-in/dual-out muffler (ending near the e-brake cable then dumping into 3" resonators. Ideally, I'd shoot to have the "dip" between their 4"-5" cases so that cable clears the 3" piping in-between.
It's possible some other placement/arrangement might be desired which is why I'm curious if anyone has needed to move that cable? Maybe the mounts on either side can be bent/moved?
Any way, if you have any "history" with interference, rattle, or whatever, let me know. It might help in installation day.
Thx!
Thx!
Thx!
Thx!
I have ARH headers/Cats/X-pipe 3" pipes going into what is left of the B&B 3" exhaust pipes. So 3" diameter all the way until the mufflers. My E-brake cable does not come into contact with the pipes. It is close but not touching. But the pipes come real close to the rear differential. I actually had to flatten the pipes with my 20 Ton HF press to clear the diff. I have the 3" pipes reduced down to the stock LT mufflers (2.75" inlets but they are even a smaller diameter within the muffler) because I can't seem to find a high flow 3" inlet muffler that doesn't drone and isn't obnoxious.
I'm thinking the new Borla Crate Mufflers might qualify. They CLAIM anti-drone.
Why was it necessary to "squash" the 3" under the diff? Seems like you'd roll over anything in the road way before it contacting with 3" pipes hanging under the differential. Also, think I've seen 3" unsquished in pictures?
What about the Corsa Pro Series CP300 series? (3 configs) It's 3" and has RSC tech.
Thank you, I did see the Corsa and Borla crate mufflers online. But I have spent so much on exhaust and mufflers in the past that I want to hear them on a similar setup before I buy a set.
Do you remember how it attached? I probably took mine off in 2008. It's been too long. HOPEFULLY, it's easy to re-install w/o pulling the c-beam (or something as unfriendly). There's not a lot of slack (if any) in my brake cable..which makes me think it would be tough to lift it high enough to pull the cable UP until the clip can (hang on the c-beam?) then release and STILL hold the cable higher.
My pipes came straight back and had no bend on them at all. I also installed it all myself and had no pipe bender. So when the straight pipes came under the differential (and the camber rod diff mount) it was hitting. Now I didn't have to squish it a lot so that it is totally flat but I did squish it at least 1/8-1/4 inch on each side. Almost like a "D" shape so the flat part of the "D" was facing the differential.
Off-topic: The Corsa C4 system is priced so preposterous, I'd never consider it -- even on a higher value restomod like mine. (You probably feel the same). PLUS...it doesn't come in 3". With installation, you could spend close to 3 grand. (And they claim it's justified. FWIW, I think they are charging double -- just to provide a lifetime warranty HOPING you don't collect). DUMB DUMB DUMB. Bet you it gets discontinued (unless they need to keep making a few just to have warranty units on hand.)
Using the Pro Series mufflers is really the only reasonable option (if you like Corsa). They are 1/4-1/3rd the price of the car specific mufflers. THAT'S how you know C4 owners are being fed unreasonable pricing....on the C4 specific model.
I think it just hung off of the C-beam (one of the openings/triangular shaped cut outs) and the round loop went around the E-brake cable. Look at the picture below of a C-beam and the hanger. My C-beam didn't have that bracket attached to it.
grandspt (04-02-2024)
SUPER COOL!! Thank you for the PERFECT PICTURE!!!!! The loop is so "tight" around the brake cable, I'm kinda surprised mine isn't just hanging there. To get one on, I'd think you'd need to wind it around the brake cable -- then lift up and "hook" over the c-beam.
Almost seems easy enough to make from a coat hanger?
