ZF6 clutch - what will hold 1000 hp ?
Ive got a forced induction build im doing, with plans for nitrous on top of that
what started this whole build plan was my spec stage 3+ clutch began slipping when temps got cooler (more power) with the e85, 15psi boost , and 75 shot nitrous.
I have found a pull type Mcleod street twin clutch (which is discont’d). They say it has a 1200 hp rating, but a user reported it slipping on the dyno at only 870 rwhp. It has organic discs. I talked wirh Fred at Mcleod and they said the reason they didnt do ceramic discs was bc they had Valeo pull type pressure plates break apart under high power levels with nitrous. He told me my key is finding a push type clutch. That would work.
i spoke with the guy at ‘Ram or Luk? (I cant remember and he acted like their push type clutch conversions couldnt hold any more than 800 hp.
SPEC claims they have a pull type twin ceramic disc clutch for our transmissions that can handle 1200 hp. But I an skeptical bc it prob uses one of the new, lower quality korean replica pressure plates - and if it does that would mean it would have the same issue that Mcleod users had with the pressure plate breaking in high HP applications. A user here has told me they have broken this clutch as well (i’ll have to get them to clarify how it broke)
so if anyone has any clutch recommendations, for behind a black tag zf6 - let me know
I had heard the zr1 pull type pressure plate has higher clamp force, but its thicker and I dont know what other mods to bellhousing, fork, ball stud, etc. to make it aork
im trying to avoid this from happening (photo below) , under boost and
nitrous spray
nitrous spray
nitrous spray
nitrous spray
800hp isnt that wild a number anymore
i told him about the SPEC pull type dual disc, with ceramic discs that SPEC says is good to 1200 hp and he said no way it is
I got a Spec Sage 5 Product Number SC425Y for my built boosted LT1. Spec claims it can withstand 1008hp and it functions just like a stock pull style clutch and it also works with my Fidanza Aluminum flywheel. I went with this option versus the competition because all the other clutches required converting the Pull style clutch over to a push style clutch and that would require quite a bit of fab work. Granted I do not have too many miles on my build I am pretty impressed that the drivability isn't bad at all considering as it's a "race clutch-not for street driving" according to the manufacturer.
yakmastermax (02-25-2024)
is it a dual disc?
do you have any photos of it ?
Mcleoud 1200hp
Part Number 7436023. https://www.mcleodracing.com/clutch-conversion-kit/p32 Kit Consists of: 7436023 1989-96 C4 Corvette (ZF 6 Speed) Steel Flywheel. External Balance Weight Kit Internal Hydraulic Bearing for 1989-96 ZF 6 Speed. S.S. AN-4 Braided Line AN-4 Male to Roll Pin Male 90-degree fitting. Grade 8 Pressure Plate Bolts The Clutch Kit is Sold Separately. Separate from the conversion above, You would need a Twin Disc Clutch assembly that bolts to the supplied flywheel in the conversion kit. 6923-07HD https://www.mcleodracing.com/rxt-1200-6923-07HD/p37 Crank Bolts – 1540 https://www.mcleodracing.com/hardware-1540/p133 Balance Service – Balance https://www.mcleodracing.com/rst-Balance/p31
Mcleoud 1200hp
excellent info. Thank you
any idea what flywheel we would use with that?
(it said flywheel isnt included - but at least i can call and reference that p/n to find out)
It is a steel flywheel. And while it isn't on the shelf it is available. My clutch is being built now by them. I just ordered direct.
dizwiz24 (02-26-2024)
was 355 rwhp/355 rwtq at that time
with occasional nitrous hits to 445 rwhp/525 rwtq power level
dizwiz24 (03-01-2024)
Serious question, what about the rearend, outer stub shafts etc? I posted a few months ago about this because I’m considering a single turbo setup with either ls or sbc in my 6 speed 89. Making the power is the easy part.
