Hard steering
Hard steering
When I first crank my 85 you have to really pull on the wheel then after that it acts fine it's only after it has sat like over night
thanks for the help Skip
Steering rack is on it's way out, they normally get much worse with cooler temperatures.
To buy some extra time a Drain/suck out and Fill of pump might improve it until you can psychic yourself enough to get and install it.
I agree, you are going to need a steering rack
Received 1,404 Likes
Morning Sickness is what this is called, common to C4s. Stiff until you get going.
You can drain or suck out and replace the PS fluid with new and alleviate it, but someday you will need a new rack.
