msd ignition
Old 01-20-2003, 11:06 PM
TopSpeedc4vette
TopSpeedc4vette's Avatar
Default msd ignition
anybody have msd in their car? do u like it or not? how well does it perform to you and your cars need?
Old 01-20-2003, 11:34 PM
Bob86ZZ4
Bob86ZZ4's Avatar
Default Re: msd ignition (TopSpeedc4vette)
I put in a MSD Digital 6plus. I don't think I can tell any difference in the power. The biggest advantage is that now I have a rev limiter.
Old 01-21-2003, 01:11 AM
DRAGRCR1005
DRAGRCR1005's Avatar
i was wondering the same thing.
digital of standard 6al?? :chevy
Old 01-21-2003, 09:03 AM
jmrl98
jmrl98's Avatar
Improved throttle response, plus pulls a little harder beyond the 4200 mark - '85 4+3. :steering: :seeya
Old 01-21-2003, 06:31 PM
TAOS6Speed
TAOS6Speed's Avatar
Default Re: msd ignition (jmrl98)
I instaled MSD ignition on my vett and like the performance I got. You will notice more when wide open throttle. The hardest part is finding a place to mount. I would suggest getting a good set of plug wires and a MSD coil.
Old 01-22-2003, 06:38 PM
cprgmr
cprgmr's Avatar
Uh-Oh, here we go again! ;)
:iagree:
Old 01-22-2003, 06:59 PM
scorp508
scorp508's Avatar
Have an MSD Digital 6+. Didn't 'feel' any different at all compared to normal ignition stuff. Idled a little bit smoother. I like having 2-stage rev limit and timing retard though. :)
Old 01-22-2003, 07:06 PM
95AquaC4
95AquaC4's Avatar
Default Re: (scorp508)
I have the Dig6+ box, the Blaster coil and the 8.5 wires. Seems to idle better, and pull better up high, but that could just be my imagination. I needed it mostly for the timing retard with the nitrous.
Old 01-22-2003, 09:12 PM
UDLUV12
UDLUV12's Avatar
I've been running the MSD-6AL ignition box since 1999.
I bought mine from TPiS, along with their 'Special Adapter Harness'.
TPiS P/N's are : 100-360 (MSD 6AL Ignition Control Box), and
100-361: (MSD Special Adapter Harness, [Coil in Cap Distributor]).
Cost was $229 including shipping.
I required it because of all the mods I have been doing over the years.
Once added, I could certainly feel the seat of the pants difference.
I have no idea what it all means horsepower wise, but I can tell you as I go through the gears, and shift 'em at 6200 RPM, it's made the combination 'pull'
so much harder.
I'm not so sure it's an item that is needed, unless you have modifications done to your motor. The Delco units in our Vettes are very good too.
[Modified by UDLUV12, 9:22 PM 1/22/2003]
To msd ignition
Quick Reply: msd ignition
