A video said you don't need a computer to control a 700r4 transmission True or False?
Hello, I finally got the engine out of my junk 1985 Corvette. The engine is going into the 1958 Chevy Viking 60 two-ton truck, and I guess the transmission is going into my 1949 Ford F6 two-ton truck (for now). I watched a video that said a 700R4 transmission only needs the computer to lock and unlock the converter. Is that true or false?
(As you can see, I did not take off one wire taking the engine out.)
Received 1,597 Likes
I have a 700R4 in my 68 Caprice, no computer t all. Just make sure the TV cable is adjusted correctly, trust me.
I can't seem to find in the forum rules where it says we aren't allowed to attempt be helpful to other members. Maybe you can point that out to us? To the OP: You can run a simple toggle switch and manually control the lockup function.
The following 2 users liked this post by Polo Vert:
mjsusa1 (07-27-2023),
TrailerPark Hero (07-26-2023)
Except for an increase in fuel consumption and radiator temperature, is there any real need to lock the converter?
Update found this picture. And now that I can read what it does, is there a significant increase in fuel consumption.
Without lockup the transmission will burn up on the highway, generally
Lockup does something to the lube circuit. I forget what exactly but I am 98% sure it has to do with planetary lube
Found my 'notes'
http://67-72chevytrucks.com/vboard/s...56&postcount=5
So it is possible to do but you must change the torque converter and modify the transmission to lube without lockup. Or else
clinebarger aka "Chris Linebarger" is one of the top 4l60/700R4/4l80e builders in the country. He walked me through my 4l80e build in 2018 and has thousands of posts helping people rebuild their units. I am familiar with his process and trust his perspectives.
There are only 2 builders I trust, clinebarger and 'probuiltautomatics' aka Dana at probuilt (700r4l60e.com) I wouldn't buy a transmission from anywhere else if I wasn't doing them myself
The converter "needs" to be locked up when in 4th gear. The planetary lube curcuit is cut to almost nothing when in 4th without the converter locked. Dont drive on long freeway trips in 4th.
When running a "non-lock up converter" in a 700R4.....You have to install a "Lube Valve" in the pump to correct the lube curcuit. This REQUIRES a non-lock up converter, The stock converter will not work.
The lock up is easy to hook-up with a dual brake switch, wire, pan gasket & some ATF, Search this forum, Ive posted on this subject alot.
Untill you do something run it in 3rd, Driving on long freeway trips in 4th WILL burn your planetaries down. I couldnt count the "Blue" gear sets ive seen from being overheated
My friend has a 1969 with a 700R4. The shop wired in a switch as stated above. He did the complete Route 66 and back from Chicago and the Power Tour with no issues. That is quite a bit of mileage.
Talfryyn (07-31-2023)
I know you are trying to do a budget build, but I would suggest going with a 4L60E and a standalone TCM. I blew the 700R4 in my car and if I do keep it automatic that is the route I am going to go.
I built the car a long time ago, but IIRC there is a 1 wire switch hooked up to the brake light switch.
You might remember this is what it is going into.
If you don't want lockup a shop will cut off the end of the shaft and use a non lock up converter. I ran one with a trans go manual shift kit for quite awhile it was very durable.
