Bleeder tool
Bleeder tool
Does anybody know if the vacuum tool for bleedingg the slave cylinder will work on a 4+3 car? I have seen people with the ZF trannies say it makes the job much easier. Can I use the same one? Does Advance or Discount rent them out?
Also, if you wouldn't mind telling me exactly where I need to look to find the slave cylinder it would be appreciated.
Re: Bleeder tool (blue88vette)
Blue, you really do not need any tool. All you have to do on these hydraulic clutch systems to "bleed" them is once they are filled, just take the clutch master cyl cap (and rubber liner) off. Just depress the clutch pedal, and watch the bubbles rise up to the master cyl. Leared that trick from GK.
