Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-10-2003, 08:15 PM   #1
jimijoe
CF Member
Default What Opti Sparc to buy? Anyone heard of Cardone
I'm gona have to replace my Opti Sparc. I'm a bit confused on which one to buy. Here are my choices.
1) Local GM dealer; Cost $642
2) GMdirect.com; Cost $385
3) Rebuilt (rebuilt by Cardone) $145
I am currently out of work so money is an issue, on the other hand I dont want to put a POS in there that's gona fail again in a year or two.
What would you guys do.
Has anybody heard of and or used CORDONE parts? http://www.rockauto.com/ref/Cardone/...html?58472.jpg
thanks
Thanks :auto:
jimijoe is offline   Reply With Quote
Old 01-10-2003, 08:29 PM   #2
DRAGRCR1005
CF Senior Member
Default Re: What Opti Sparc to buy? Anyone heard of Cardone (jimijoe)
if i am not mistaken, you are talking about A-1 Cardone. i have not had much luck with their products in the past. i have not ever purchased a distributor from them but i have purchased blower motors and brake calipers and things like that. i am a mechanic at a commercial vehicle repair facility and the owner of the shop told me that i was not to install their stuff any more and to only buy delco. i can imagine that they only put a cap and rotor inside the unit and checked for the opti eye to function and boxed it and called it rebuilt. if i was doing the job i would not risk it. it is it worth it to have do it again for about $240? YOU GET WHAT YOU PAY FOR! :flag
DRAGRCR1005 is offline   Reply With Quote
Old 01-11-2003, 06:08 PM   #3
flyersfan1088
CF Senior Member
flyersfan1088's Avatar
Location: What did the 5 fingers say to the face? SLAP!!
Default Re: What Opti Sparc to buy? Anyone heard of Cardone (DRAGRCR1005)
:iagree:
I've had nothing but problems from A-1. I know money is tight, but I would seriously consider going with Delco.
flyersfan1088 is offline   Reply With Quote
Old 01-11-2003, 09:00 PM   #4
bogus
CF Senior Member
Send a message via Yahoo to bogus
Default Re: What Opti Sparc to buy? Anyone heard of Cardone (flyersfan1088)
I would call Jeff Kopp at Superior Chevy... GM parts for cheap...
1.800.728.8267
he is carfan18 around here... cuts great prices for forum members!!!
make sure you tell him your a forum member... and tell him I said hi!
bogus is offline   Reply With Quote
Old 01-11-2003, 10:52 PM   #5
superlund
CF Senior Member
superlund's Avatar
Default Re: What Opti Sparc to buy? Anyone heard of Cardone (bogus)
Check this one out;
http://www.dynotech-eng.com/dynaspark.htm
:seeya
superlund is offline   Reply With Quote
Old 01-12-2003, 08:33 AM   #6
luvmy92
CF Senior Member
luvmy92's Avatar
Send a message via AIM to luvmy92
Call Jeff Kopp or get it at The Last Detail. Bothe are around $325 for a brand new AC Delco unit I believe...
Mike
luvmy92 is offline   Reply With Quote
Old 01-13-2003, 12:48 AM   #7
wake
CF Senior Member
wake's Avatar
Send a message via AIM to wake
Quote:
if i am not mistaken, you are talking about A-1 Cardone. i have not had much luck with their products in the past. i have not ever purchased a distributor from them but i have purchased blower motors and brake calipers and things like that. i am a mechanic at a commercial vehicle repair facility and the owner of the shop told me that i was not to install their stuff any more and to only buy delco. i can imagine that they only put a cap and rotor inside the unit and checked for the opti eye to function and boxed it and called it rebuilt. if i was doing the job i would not risk it. it is it worth it to have do it again for about $240? YOU GET WHAT YOU PAY FOR! :flag :iagree:
Another :iagree: here...
I used them when I was younger and the quality was way behind what I had with OEM replacements... Their cap and rotor kits on my older cars were always just a "little bit off"... They never went on without some type of modification (filing, tweaking, etc)... The caps were junk and never sealed correctly on the distributor base... I would hope they have better quality in something like an optispark, but I wouldnt' want to take the chance...
I'd get one new over rebuilt anyday... Who knows how long the optical sensor or bearings will last if they didn't fall out of spec on the rebuild...
It always cost me more in the long run, either time, money, aggravation, or all at the same time when I used non OEM parts...
wake is offline   Reply With Quote
Old 01-13-2003, 09:26 AM   #8
93Polo
CF Senior Member
CI 3-4-5-9 Veteran
93Polo's Avatar
Send a message via AIM to 93Polo
Default Re: What Opti Sparc to buy? Anyone heard of Cardone (luvmy92)
Mike
:iagree: Always had great luck with The Last Detail :yesnod: 94 should have the updated opti. If not I would convert over to the new opti.
93Polo is offline   Reply With Quote
Old 01-13-2003, 09:46 AM   #9
bogus
CF Senior Member
Default Re: What Opti Sparc to buy? Anyone heard of Cardone (93Polo)
Mike
the 94 has the old style opti. it started in 95.
if you're serious about converting, that is not a cost effective plan... consider the new Dyno Tech Engineering piece... they are much better than stock, or at least seem to be, and are cheaper than converting.
Reload this Page What Opti Sparc to buy? Anyone heard of Cardone
Tags
cardone, fail, opti, remanufactured, reviews
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
