Skid pad test C4 with modern rubber
#81
Pro Mechanic
Copy that.
#82
There is some talk about the C5 and newer cars having an advantage in Track Width. While I find this certainly true on a skid pad, I would also consider it both and advantage and disadvantage when you need to turn both left and right as long as you are in the confines of a given coarse. Put a Corvette and a Miata on a tight Autocross and the smaller car has such an advantage that it makes up for lack of Track Width to a point. And I would consider the faster and wider the course this would reverse at some point. Just like any other suspension change there is always a compromise to be had.
#83
Thanks for all the great info! As stated the post was just an interesting thought i had about skid pad and how it is mostly about rubber compounds. My initial premise has finally started to come out in that some of you agree the numbers would be close between the older and newer cars. I never said anything about handling better auto cross or road coarse performance at the beginning. I just thought it would be interesting to see. Having a C7 and C4 street driven cars i can appreciate both for what they are dare i say raw vs refined. That said i learned a lot about C4 handling and race handling in general through your experienced knowledge of these cars.
i seem to recall cheverolet having to retune the MRC of the C7s at some point to “fix” them i thought because of the performance deficits which showed up in real world driving. Correct me if incorrect.
I still have to argue, maybe my non engineering mind struggles with, on weight transfer of a vehicle. Drag racing for example is all about transferring “weight” to the rear to increase traction to the rear tires. I am sure that the engineering behind it is about changing COG, centrifugal and centripetal forces etc and obviously not moving components (mass) of the vehicle but to the simple minded novice effectively weight is being moved/transferred from one place on car to another to improve specific performance parameters. Road course i imaging the same is true to load a tire or unload a tire for better lateral traction. Perhaps weight is the wrong term and maybe force is more technically correct but i am just a simple minded guy.
Computers, ie traction and stability control parameters and devices including MRC (which is computer controlled to an extent) proven by chevys MRC tuning via software which was done in 2017 I believe are helping you drive any modern car. Now based on power levels and drivers to dumb to know their limitations i think they are a good thing and most instructors tell new drivers to keep that stuff on, again good advice for newbees like me. But everyone should know by now that modern cars are computer controlled and those computers are able to adjust faster than people can. In aircraft technology computers are so “good” they can literally fly an airplane with almost no lift capability based on outward design. Computers are co-piloting pretty much every modern car and they are getting better. To learn i think a low powered less computer controlled car helps, me anyways, learn better than relying on computers to bail you out. Hence learning everything you can on inexpensive slower more analog vehicles makes sense to me. Everyone learns differently but as many pointed out seat time is the best way to gain that experience and learn those vehicle dynamics as is the book knowledge and learning from smart folks like you all.
#84
In drag racing and road racing, unless you change ride height or wheelbase/track you cannot change the amount of weight that is transferred for a given acceleration force. As I wrote before, even with no suspension at all, the weight still transfers. Pages 6-7 of this article give you the diagrams and math that shows this. The CG moves very slightly as the car rolls or pitches, but not enough to make meaningful change. However, suspension kinematics and wheel rates definitely can change the rate at which the weight transfer takes place. The higher the roll centers or anti-squat/dive and the stiffer the springs, suspension, and damper rates; the faster the weight transfer takes place. This is where a fair amount of the "magic" of suspension design and tuning takes place. We know a lot more about these transient conditions in 2022 than we did in 1982, since we now put cars on 7-post shaker rigs with high-resolution load sensors and use lots of computing power to see what's happening as the car moves around on it suspension in every conceivable way.
#86
Pro Mechanic
Yes, you are correct: moving a 35lb battery from over the front axle to over the rear axle would be a 2% weight distribution change. My mistake.
The worst I've seen is from a Road and Track review that showed 52/48, but that was an estimate with driver, so it's pretty much useless. I found another resource that says the 1990 ZR1 had 1750/1729 on its front and rear axles, which is 50.3/49.7. And Corvette Action Center says the LT5 was 39lbs heavier than the L98. The LT5 wasn't actually 200lbs heavier than the L98 or LT1, and I seem to recall seeing that there was a big confusion with whether the engine weight listed for the LT5 was with trans or without, thereby causing people to mistakenly believe it was 200lbs heavier when most of that was actually trans and clutch.
#87
I don't know what to believe for sure. However, I find it incredibly hard to believe that an all-aluminum engine with the same bore spacing and displacement weights 150lbs more than an iron-block LT1. I realize the LT5 heads are much bigger and contain four cams total and that it has a more complex intake, but there is typically 75-80lb extra in a standard iron SBC block than an aluminum equivalent (like Brodix or Dart), and the LT5 block should be similarly light. It seems to me that in similar "dressing," the LT5 probably weighs 30-40lb more.
In the book Corvette Specs by Michael Antonick, the dry weight of a dressed LT5 for a 1990 is 596 lbs and the dry and dressed L98 from the same year was 557 lbs (see pic below). The LT1 weight is very similar to the L98. This is where the 39lb difference comes from, and I would put my money on this being correct. I think a lot of the goofy-huge weight differences include a transmission and flywheel on one engine and not the other, or confuse pallet/crate/shipping weights with a dry/dressed engine weights, or include a 40lb flywheel on one engine and featherweight flex plate on the other. Some of these are the same specs that say an LT4 weighed about 150lb more than an LT1, which of course insane.
#88
Pro Mechanic
It certainly isn't that easy to ascertain LT5 or ZR-1 weights....that's for sure. Conflicting and dubious data...and that's when you can find any. I don't think comparing an aluminum small block to the LT5 block is all that valid. The LT5 block is a brick **** house with deep skirt, plus the ladder girdle for the bearing caps that is aluminum encapsulating cast iron. Then you got the weight of the heads, that gigantic intake, I could see it being heavy. I am not sure I see 150 lb more heavy, but more than 39 lb, I can see pretty easily.
I will be doing some top end work on a '90 ZR-1 later this month. I'll throw it on some Corner scales and then do my LT1 so we can compare. Then we will have some real info.
#89
Damn good information here. Should be a sticky.
Modern tires and modern shocks really help the car but it's old. If you drive them hard you can embarrass people. 😂
THe C4 is retired from national events now but I happened to run a Divisional for Great Lakes Division at WVU Parkersburg.
Maybe I should delay retirement since BS is weak, new set of tires and go hunt unsuspecting victims. Hopefully without cone issues, feel like I'm driving better this year too.
I was the fastest, oldest, and stockest Corvette on site. On 192 run 5k mile Goodyear Supercar 3s no less.
I tuned some heads.
I tuned some heads.
Facebook Post
#90
Pro Mechanic
LOVE it!
Keep doing what you're doing.
#91
Pro Mechanic
Wait, you beat an 06 C6 and a 06 as well!? How....wha....
#92
Something that cannot be measured on a skid pad is driver mod. I was getting 98% of the potential out of the car. They weren't even coming close to that. The one car was on Hoosiers....get gud scrub.
I'm not even really fast. I'm quick but I'm not fast.
#93
Pro Mechanic
I know. I agree with you. Driver mod, tires, those are the places that you find massive improvements or differences.
Not so much in a few percent of weight distribution one way or the other.
Nice to see you post, by the way. My son and I went to an auto cross race two weekends ago, it didn't go that well. You should search up my posts and read about it.
#94
Even though the LT5 is aluminum the parts inside that make the thing run aren't... and these items aren't necessarily light. LT1... smaller aluminum heads, 1 cam, 16 valves with one simple timing chain. LT5... 4 cams, big *** heads with 32 valves and the associated springs, 3 timing chains that loop over heavy gears all the way up to the heads. The intakes on both are aluminum but I think it's pretty safe to say the LT5's weighs way more. All of that stuff is heavy. And to add to it... LT1 holds 4.5 quarts of oil, LT5... 12.
None of these items individually are all that much, but 10 pounds here, 15 there, etc. certainly add up. And like I already said part of the issue is if the engines are weighed with the dual mass flywheel or not, and if they are dry weighed or measured with fluids... I mean the LT5 holds about 15 extra pounds in oil alone.
Anyway... tires. Man these new compounds are some serious business. Even for street tires. I just put Michelin's on my GS and it's like the car is glued to the ground. Compared to the factory GS-C's it is just not in the same neighborhood
#95
#97
I don't know the correct answer, but despite being aluminum, the LT5 should be significantly heavier because of the DOHC heads. That is 4 cams vs 1, much physically larger heads, much larger larger timing set, much larger timing cover etc. This is going to make the engine both bigger and heavier. Also I bleive the LT5 has Iron Cylinders. All that siad I agree the basic block is should be lighter on the aluminum engine, but not by enough to make up for the rest of the motor I don't think.
#98
Pro Mechanic
I disagree on the block being "a lot lighter". It's deep skirt. It's got a cast iron, aluminum encased girdle. I found more references from. HOTB where they actually put the dressed engine weight at 600 lbs -which jives with the earlier post where they said 150 more. We can debate LT5 weights all day and get no where. I'm going to be working on a '90 ZR-1 in a couple days. I'll try to corner weigh it, then my '92. Put this lore to bed.
Back to the value of skid pad numbers....I kept my mouth shut earlier when they were lambasted as "useless", but I'm going to say, "sorry, but no". I did another track day yesterday and the reality of being on a real track, is there is a LOT of time spent, mid turn, just grinding the tires off the car. If you set up for the turn decently, that kind of turn is steady state, max G cornering. What is a skid pad test? "" "" ""
It's relevant. It ain't everything, that's for sure, but at those points on the track, a car that can skid pad higher, will drive away from the car that G's lower.
I am likely to agree with you (MM) much more strongly, if we're talking Auto-x; because there are way, WAY more transient maneuvers, less looooong, steady state cornering and throttle/braking transients are more violent due to the lower speed/higher wheel tq, in auto-x. But on a big track....Skid pad performance matters because there is simply SO much time spent, mid turn, max G, steady state cornering.
#99
#100
Pro Mechanic
Even the reference I posted above says the LT5 weighs 596lbs. So I don't think we disagree on that weight. But the L98 and LT1 are way heavier than the 450lb you imply (at least fully dressed, as per the LT5 weight). The L98 is more like 550lb dressed (557lb per my reference above). An LS1 is more in the range of 450lb.
IME, two cars that have somewhat similar weights, track widths, CG heights, and tire widths can skidpad very similarly on the same type of tires. OTOH, those two same cars may behave very differently on the brakes, throttle, or transitions; and that's where you're going to find the most meaningful differences between two cars. IOW, skidpads usually don't tell you much about the qualities of the car, except the most fundamental aspects of it.
