Please recommend me a good injector set for 92 LT1 c4
Dear Guys,
Came to replace the old rochester injectors, cos one of them performs very badly even after proper cleanings.
Please recommend me a good, trusty replacement set/brand/product that proved to be perfect for you!
...(with website to purchase them if possible!)
Thank you in advance!
Regards
Gabor
Regards
Gabor
https://fuelinjectorconnection.com/c...roducts/92-lt1
I've used the bosch 3s in an l98 and my lt1 and they worked great. Actually noticed a smother idle, better throttle response.
I put these in my 93 LT-1 and they work great! https://fuelinjectorconnection.com/p...l-injector-set
ggabesz (05-10-2022)
I contacted FIC in re: to replacing them in my 92 and the ones they recommended were the same as for a L98. They told me to just note in your order that it's for a LT1.
These were the Bosch 3's.
The link from post #2 takes you to a page on FIC's site that says those Bosch IIIs are a one year only injector for 92s. I'd like to find out what those originally came out of as the factory ones are NOT Bosch IIIs. I can get fuel injectors for a couple of dollars a piece out of the wrecking yard instead of $229 for 8. For my 93 Jeep I found online that the 96-00 Dodge Neon injectors were the same spec, but 4 hole (basically Bosch IIIs). I got a set out of the wrecking yard of those and it made a noticeable difference in my jeep. The old single hole injectors are not as efficient as the 4 hole.
That was for rebuilt ones. I had asked them what was the best bang for the buck and that is what they recommended.
You cannot go wrong with FIC. Just give him a call and he will be the best option. As Blue Bucket List stated the rebuilt ones are great. i put them in my 92 and they were a noticeable improvement over the factory ones.
I think I found the part number. 0280155715. Common on 96 Frod 3.0L V6 DOHC found in the Taurus. I found an old post on this forum stating the stock 92 computer is actually set at 23.8 lbs for the injectors. I'll give these a shot and probably make a new thread with my results. It will be a while before I get these. I'm not going out of my way to do this. I'd also like to put some miles on my car after I have done a bunch of other stuff and get a good base line.
I've wondered whether there's a Denso / Dephi 12 hole fuel injector that would work on a TPI / LT1...
If you've got 24 lb injectors, the 2000-2004 Toyota Tundras come with a 250cc injector that is very close on flow and should have FANTASTIC atomization, but, I'm not sure about the height or orings...
2006-2010? Tundras had 270cc injectors, there are 330cc / 31.4 lb injectors available for the 2006 Tundas, too.
There's considerably bigger ones from 2011-2015 Toyota Scions and the Nissa G35/G37s and GTRs.
-Not sure what size injectors came on the 92 LT1...
I've been meaning to do the spec hunt to find a 12 hole that would work but it just didn't make it to the top of my priority list yet...
Adam
Adam
Any change in MPG?
