Auto to stick
Auto to stick
I have an 86' that was a 4+3 about 20 years ago, it now has a ZF6 in it. I also have an 84' with an automatic. I have all the old parts from the 4+3 and was thinking about putting them in the 84'. My question is, Does the automatic car have the mount built in it to hold the shifter? Thanks, Joe
The box that the 4+3 shifter is in Is Not in the automatic floor pan so I would guess you would have to find a Donor tunnel section and piece it in. Or go ZF-6 Speed where you would cut the shift tower hole.
. But with the ZF there might be Clutch/Flywheel fitment problems with the use of a very early crank that I am sure have already been sorted out.
