Stock Hood Clearance with this planned build?
Cruising
Hi all,
Total noob. 1985 Corvette
I ordered the following engine from Jegs when they had their sale on last week: SBC 355
I'm planning on using this EFI as well.
Does anyone know what intake / air cleaner (perhaps a carb hat) combination will fit under the stock hood? I had my eye on this Weiand intake.
Hoping I don't have to cut any holes.
Appreciate any insight.
Thanks.
Thanks.
Hi all,
Thanks.
Thanks.
Cruising
That's good to hear it worked for you.
That's true, I can always order two air cleaners, use the one that works and send the other back.
Thanks for the reply!
If you are going for max hp a thin filter or drop-base filter setup is going to kill quite a bit of power. Welcome to the stock hood clearance and fitment paradox.
Cruising
