1985 Exhaust manifolds
We’ll…..yes & no. They were stock, but the smog pipes have been removed and welded shut (that is ok as long as they don’t leak). Also, the heat shields have been removed and that isn’t too good as they run extremely hot and melt everything in the surrounding area. Best to reinstall those. The manifold bolts are also cobbled on there.
If that is the case, why did GM engineers install them in the first place? If the headers are ceramic coated inside and out, they generally do not need heat shielding. I’ve had headers that glow cherry red clear to the collectors, when under load. I’ve also seen the plastic brake boosters melt on C4’s with tubes.
P.S. Take your header equipped vehicle at night, find a decent steep grade (oh 4-5%) hammer the throttle, climb the hill in as high a gear as possible (load that engine down) and when you reach the top, pop the hood and you “Will” see glowing headers guaranteed. A good dynamometer can accomplish the same thing. It was on a dyno that I first saw mine glow. I had a friend run it up and I (being a dyno tech) loaded it down to maximize the timing and tuning for my 5500ft above sea level location.
LiveWire1 (11-26-2021)
Now your talking apples and oranges. The smog equipment installed on these cars was to meet EPA regulations. Anybody with any knowledge of performance automobiles knows that you want the heat to exit the tailpipes and not accumulate under the hood. Have you ever wondered why the people in the know use header wrap to wrap up their headers. Look into it. All of this, is just “Common Sense”. Now I am through arguing and wasting my time trying to educate.
Put your shields back on if it makes you feel good, but im not going to run the **** out of my car just to see the exhaust manifolds glow LOL!!!
As far as educating, just because you are giving your opinion doesn't mean your educating anyone, I've been working on cars for 40 years not much you can teach me.
farmer661 (11-29-2021)
