Where is the Fuel Relay located in a 1985?
Hello simple question here. I am installing a Sniper 4150 system and need to locate the positive wire to the fuel pump. I believe it is Tan / White and located between the brake booster and the wiper motor. Is this correct? Could someone post a picture of the location and identify correctly the wire color? Thanks
That IS NOT BLOWER MOTOR!!!
If FSM is to be believed E - Fusible Link, C - ECM, A - From OPS SPLICE, B - GROUND, D - ALCL. TAN/WHT is Fuse to FP @ Tank Unit
Do you have the FSM for your car?
Thank you I have the FSM. However it is with the car which is located at a friends shop 60 miles away. Now I know where it is and the page for the FSM.
Thanks so much!
Thanks so much!
