Lower front air dam protection?
Whenever driving my c4 and i have to get into my driveway sometimes ill scuff the lower lip air dam thing. Would using a thin piece of weatherstripping be a good way to protect the bottom while not making it look to noticeable? What do you guys use?
I don't think weather stripping will help, the foam material will just get shredded and look worse than a scuffed spoiler.
I do the angled approach as well. My rolled curbs will scrape on exit but not entry. Easy to forget so occasionally I still scrape it. Fortunately they are cheap and easy to replace.
941YYG (05-29-2021)
Received 1,597 Likes
Both my 89 and 13 do the same thing in my driveway, the air dam is a sacrificial part that is easily replaced. I do take a file to the "strings" every so often to make it look presentable.
941YYG (05-29-2021)
941YYG (05-29-2021)
hmm I'll try and see if i can get something flexible but also durable under the dam and see if that helps. Kind of like how new chargers have that yellowish black bumper guards. Something like that is what i want just so that it stays intact.
Rather than trying to modify the air dam, maybe ramp the driveway to street junction with some asphalt mix, or even a small strip of wood? I had this problem when I lived in FL, and a small piece of 1x2 did the trick.
I angle drove it but the wife's W216 was also very low and she doesn't do it well so I am cutting the approach up and the curb is cut down. So instead of a 4 inch drop, it is a 3 inch drop.
My 86 is a Z51 that came with the taller air dam, I bought the shorter version for like $50
