Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-13-2002, 08:26 PM   #1
vetracer
CF Senior Member
vetracer's Avatar
Default Which way do the crush washers go on Delco spark plugs for '86 alum heads?
There is a washer that comes with the plug that is larger in diameter on one side. Is there a certain direction it should go? On the old plug, it is the same diameter once the washer gets "crushed". Anyone know?
Click the image to open in full size.
vetracer is offline   Reply With Quote
Old 12-14-2002, 12:04 PM   #2
vetracer
CF Senior Member
vetracer's Avatar
Default Re: Which way do the crush washers go on Delco spark plugs for '86 alum heads? (vetracer)
C'mon, guys, this should be an easy one...
Old 12-14-2002, 12:17 PM   #3
TA
CF Senior Member
TA's Avatar
I dunno, I assumed when they came out of the box that the washer was already on the plug in the right direction. Thats how I installed them.
TA is offline   Reply With Quote
Old 12-14-2002, 12:27 PM   #4
vetracer
CF Senior Member
vetracer's Avatar
Default Re: Which way do the crush washers go on Delco spark plugs for '86 alum heads? (TA)
Mine didn't. They are all loose in the boxes. Oh well, if it were that important I guess they would either put them on or provide instructions. I think I'll put the smaller side against the cylinder head.
Old 12-14-2002, 12:32 PM   #5
scorp508
CF Senior Member
scorp508's Avatar
That is what I always do, I figure it seats into the plug boss on the head better that way.
scorp508 is offline   Reply With Quote
Old 12-14-2002, 02:02 PM   #6
vetracer
CF Senior Member
vetracer's Avatar
Default Re: (scorp508)
Thanks, Scorp. I knew I could count on you to help! :cool:
Reload this Page Which way do the crush washers go on Delco spark plugs for '86 alum heads?
Tags
crush, direction, dose, plug, plugs, plut, put, seat, spark, spart, washer, washers, way, which, witch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
