Crank hub install help
Hello, I am trying to install my crank hub and came to a couple of speed bumps.
1. What is this round thing? I can't find a mention of it in my FSM but it exists and it was on my shelf next to my crank hub. Should have paid attention while taking stuff off but here we are. Also, Do I need to remove the key that the crank gear is on before installing the hub? The hub doesn't have a key slot in it so I know I need to take the first one off, but it is hard to see if the second one will get in the way.
Do you have a '96? If so, that's the Crank Position Sensor tone ring. It goes on first, and is keyed. The hub is designed to but up against it when installed (and is why the '96 hub is 0.100" shorter than the 92-95).
That explains it. I have a 94, but am running a 96 timing cover, gen 2 opti, elecatric water pump and a normal timing chain so that circle thing came with my 96 timing cover. Appreciate the help. So that means I don't remove that first key then, only the second.
To add to the above, here's a photo I stole from an eBay ad that illustrates the differences pretty well:
Thanks for the help guys! I don't really want to take the timing set apart so I may just look into getting a letter hub. Since my car is still running obd1 do I need to do the crank sensor? I just have the 96 cover to account for my gen 2 optispark.
You don't need it, but if you don't install it you'll need to put a bolt or something in there so that you don't spew oil everywhere obviously. If you want to use an OBD1 hub, just leave the CKP toothed ring out and use the OBD1 crank key.
