Wilwood 6 piston brakes
Kinda hard to tell here being 1 in the morning, but there looks to be at least 20mm between top of caliper and inner surface of the wheel.
Sometimes I wish people made kits that fit 84s... and I wish that they would fit under stock 16s because I like the way they look and then I don't have to hunt wheels with the early offsets... but I can dream lol.
Casethecorvetteman (01-29-2021)
Fitment is going to be based not on the diameter of the wheel but the shape of it.
The FNSL6 C4 13" front kit:
The 85-87 kit requires .180" or 4.6mm with air gap.
The 88-96 kit requires .750 or 19.1mm with air gap.
You'd do well to compare that info to the inside of the wheel. The narrow gap is all but a sure thing, the later kit taking up a bit more room as the caliper is mounted closer to the wheel in this case due to a different aluminum hat requirement.
How much clearance is considered safe between caliper and wheel? Would 2mm be about correct?
These Bridgestones suit this car quite ok, and they belong on there, so i'd be very reluctant to change them.
84 4+3 (01-29-2021)
My 89 had those wheels on it when I bought it. I ended up selling them to a Callaway collector.
As for the clearing the wheels, would you be opposed to swapping the studs and adding a spacer?
Spacers would not be ideal, the fronts are already flush with the Aerobody.
Former Vendor
Yes 2mm would be an acceptable minimum amount. Some kits I've produced have less but you best check all your wheels to it!
Obviously bracket or hub flex could compromise this...
If we were to assume the JL9 caliper is dead flush with the wheel mounting surface, that should leave around 3mm, but i think those JL9s do stick a few mm past the hats. Won't be much though.
The following 3 users liked this post by SuperL98:
Would they foul on anything if they were mounted further inboard? Would this cause any issues?
So further to that, if i could get the kit with a different hat, such as these options:
https://www.wilwood.com/Hats/HatProd?itemno=170-12314
Or https://www.wilwood.com/Hats/HatProd?itemno=170-15555
Instead of the kit standard: https://www.wilwood.com/Hats/HatProd?itemno=170-6837
I should then easily be able to make this work, assuming the caliper can mount an extra 2mm-4.5mm further inboard, which it should, because the instructions mention shimming it outboard further and if the bracket went on the inboard side of the mount instead of the outboard, i should be able to get that extra space, if indeed i need it.
#33
Former Vendor
The shimming will be minimal. Allowing for variation in bearings, ducting plates etc. Maybe .065" roughly. And you'd have to mill the brackets down. Then there won't be any thread left....
#34
Not sure why there isn't brackets made to fit the calipers further inboard toward the centerline of the wheel rather than so far out toward the outer edge, there is a ton of space there, yet there is no space further out, they would fit under so many more wheels without having to waste a fortune on changing the wheels. Especially on a car like mine, where changing wheels really is not an option.
You clearly make the hats to do it, so why not the brackets???
#35
I have an update to this, incase anyone reads and wonders if they'll fit.
They fit.
There is about 5mm between spokes and caliper, and about 2-3mm between top of caliper and inner barrel of the wheels.
I reckon they'd damn near fit under 84-87 16" Corvette wheels too, if i knew the inner barrel space.
The diagram on the Wilwood site is WRONG, it states outer radius of caliper is 188mm, it isn't even 184mm. Better to give a larger number than a smaller one i guess.
The outer radius of the forged 6 piston Wilwood calipers is a fair bit less than J55 or C5 calipers.
The stopping power is significantly more too.
They fit.
#36
I have a 4-piston Wilwood Forged Superlite Calipers and 324mm x 30mm rotors under the stock "late" 1986-1987 wheels made by Enkei. The "early" 1984-1986 wheels that are made in USA does not clear the calipers.
I bought th calipers back in 2006 ( 120-7429L and 120-7429R and I see that they are not available any longer ).
https://www.wilwood.com/Calipers/Cal...mno=120-7429-L
These 1986 wheels look the same from outside.
Made in Japan by Enkei
Made in U.S.A.
These are old pictures from 2006 during fabrication, The final bracket was made from thicker material.
Made in U.S.A.
Casethecorvetteman (11-14-2021)
#37
Made in U.S.A.
Made in U.S.A.
Thanks for those photos and measurements
#38
https://www.wilwood.com/Rotors/Rotor...emno=160-12785
#39
I've thought about trying to figure out a way to make the calipers off my truck work on the vette... They're a fixed caliper 4 piston type similar to a brembo. Once I fixed the master cylinder and brake booster I haven't wanted to as much because the brakes are pretty good now.
