BEST BRAKE PADS
BEST BRAKE PADS
A few years ago I upgraded my front rotors to 13" off a 96 , now I need new pads , our 90 convertable is a daily driver and when my wife lets me drive it I am not shy of driving it to Win ! :D
What is considered the most bang for the buck on brake pads these days ?
Thanks for your inpute :cheers:
Re: BEST BRAKE PADS (Joe)
I would get the pads form Napa. Ceramix I think the call them.. The dust that come from the pads will be white. I have the Hawks on my car now and I have to wash the rims every few days..
Re: BEST BRAKE PADS (corvette0096)
If you are looking for a good cheap pad then go to Advance Auto Parts. I bought my front and rear pads for a little under $50 and they have a lifetime warranty too. Now I have a daily driver, and I do no drag racing and no autocrossing with mine so I wasn't looking for a top performer.
Cruising
I installed the Wagner ceramic pads on the front of my Wife's 96. Very little dust and no squeaks.
Highly recommend them even though they set me back around a c note. :(
Dan
Dan
1 Post
Cruise-In III Veteran
Re: BEST BRAKE PADS (T'sVette)
I've had a set of 25 dollar generics I put on the front of my 96 a couple weeks ago and honestly, they work very well... even from 60 MPH panic stops they work fine. They dust a little more then what was on there... but the dust comes off very easily. They work well enough that I just put a set on the back today.
This will hold me over until I put the C5 brakes on the front.. then I'll prolly go Ceramix all the way around.
St. Jude Donor '04 & '05
So what about the kit sold by Corvette Central...4ea. drilled rotors and the compatable shoe's...like $499.00....is this a good deal or what.....I wanted to order but $$$$$$$$$$$$$ not ready at this time....what do you think for your upgrade??????
thanks
tony
:cool:
thanks
tony
:cool:
Re: BEST BRAKE PADS
it would be nice if you state what hawk pads you run. there are only about 8 different compounds. same with raybestos, many compounds.....
[Modified by larryfs, 1:27 PM 12/1/2002]
Well I had to do something with the quickness' , I did find out a few things , the 13" rotors where an option in 1990 ! yet they use the same size pads !
Turned out my rotors where beyond turning , I priced around and AutoZone was the best at $90 for 1 and $89 for the other , think the right was a $1.00 less then the left and they are directional not like the stock 12" rotors ! As for pads I had tried Raybestos Brute Stop when I first installed them and they made noise while driving , took them back and put the stock ones on , no problem till now , I was advised then to go with Performance Friction pads , from a fellow who did Autocross in California ,could not remember the name till the guy at AutoZone recommended them yesterday , back then they where $79 now $55 so we will give them a try , had to order the rotors so I put the old ones back on and the original used pads from the 12" set will work till the new rotors arrive Tuesday ! I get this mess fixed and will need to do the backs as I did put the bios brake spring in the master cylinder so they are no doubt down as well ! Wish me luck :confused:
Location: No more yankee my wankee, the Donger is tired!
1 Post
Re: BEST BRAKE PADS (larryfs)
I went through 2 long track days, plus around 13,000 miles THe only fade associated was the crappy calipers not being able to keep up for prolonged use.
Re: BEST BRAKE PADS
I doubt your fade is assocaited with the calipers. unless they spread apart, which I have only seen under full race conditions.... and then they are pretty much garbage.
It's probably the HPS pads fading, or the fluid not being fresh.
[Modified by larryfs, 11:20 PM 12/1/2002]
1 Post
Re: BEST BRAKE PADS (Jeffvette)
street pads and 2 piston calipers can only take so much. if your doing 100mph speeds over and over you will want monoblock 4-6piston calipers and something like a hawk blue pad. the hps and hps plus if street driving is done also. physics just starts really comming into play when you want to stop a 3200lb moving object.
[Modified by gtsyellow, 6:31 PM 12/1/2002]
Re: BEST BRAKE PADS
>>Not the fluid as it was replaced with motul 600 not to long ago, and the pads were frsh, so no reason for them to fade. <<
fresh street pads will fade under track conditions. They can only take so much heat.. What makes you think the caliper is "fading"? I suggest you get cooling ducts first. If you run street pads with new race calipers, you'll likely experience the same fade. You have a heavy motor in the car, you need race pads, and expect them to eat your rotors.
[Modified by larryfs, 2:38 AM 12/2/2002]
