Headlight Upgrades
Headlight Upgrades
Anyone upgrading their lights on their C4? What did you use?
I went with these a few years ago after they were recommended on here.
They install right in place of your old ones. These are set up to give a very crisp focused beam actually setup for driving on the roads. I am still using the bulbs that came with the setup and they're plenty good for me. You can use any H4 bulb you prefer although I do believe I read that you may need to upgrade the harness plug if you go too powerful. You'd want to research that first though. Like I said, the ones that are included are pretty good.
Be careful on the $60 LED 5x7 kits that a lot of people are recommending on here (for the whitish looks of the light), not actual real down road high speed night driving performance
i dont skimp on my c4.
if going LED’s I wouldnt do anything less than JW speaker, and thats $400 a pair
you get what you pay for
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I am just curious because after finishing the shifter last night, I took it out for a drive. I think it was the first time I had been in it at night in a long time... anyway, the lights suck! Right now, it is filed under possible upgrades.
I don't know what year you have, but I did a writeup on converting the '91-'96 to LEDs. The LED headlights I have are $86, so no they're not JW Speaker $400 headlights. But they were an actual great upgrade over stock; I could actually see signs and lane markers at a distance, and they have a sharp cutoff so as not to blind oncoming drivers. I suppose it could turn out in a few months that they'll stop working or start flickering or something, but so far they've been great.
Theman5 (05-15-2020)
I installed a set of LEDs from Amazon on 1986. Pleased with color, brightness and beam pattern. Slight modification to headlight bucket was needed to fit.
Currently $86 for a pair
https://www.amazon.com/dp/B07G31G4VB
https://www.amazon.com/Headlights-He.../dp/B07G31G4VB
I am not a wiring and electrical expert.
I feel you, I don't skimp on mine either, but I also don't believe in just buying the most expensive option because it is expensive. $400/pair isn't bad if it only saves the car from a deer 1 time. Perspective Are they really that much better? So, for all these options, is there no wiring modifications? Was that just the older HID kits that required wiring modifications and ballast to be installed?
he also recommended ‘truck-lite 5x7 ‘ as well but youll pay $325 per pair for those.
by that point, id just rather get the best.
oh yeah and dont go off of advertised lumens. Its a theoretical output based on adding together the chipsets lumen output.
theres thermal and optic losses that arent being unaccounted for
these recommendations come from Daniel Stern lighting bc he IS an automotive lighting expert.
This ... you dont want the ones with the expensive lense heaters (unless you drive in snow/ice)
i would call JW Speaker’s tech support, tell them what you have and just double check this would work best.
KyleF (05-15-2020)
I did not. They fit into the buckets and the chrome trim ring held them in place as stock, and the wires plugged straight into the harness as stock. They aren't a perfect fit, but thanks to that trim ring they are held in place properly and aligned.
KyleF (05-15-2020)
On the 1986 The first side I did extensive mod to the bucket housing. Second side I only had to drill a hole for heat sink to clear. Probably the first side just needed the hole drilled also. No wiring mod needed.
FYI: I contacted 'headlight revolution' which wants you to believe they do extensive testing about the amazon LEDs. Of course they aren't the hundred of dollar ea ones they sell. I never heard anything back on it. If they did compare them to the $$$ ones and it showed well, they might not publish that info for they sell the high $$$ ones. mI basically used their videos to compare to the amazon ones. I was very impressed as already mentioned. I don't have a lux meter like them so I couldn't measure the effective amount like them.. But I will say is don't squat down and look into the beam !!
Plus the amazon one should be returnable if they don't work out for you !!
I have a phone with a Flir IR camera , but no lux
a lot of those websites rig their reviews to favor what they sell and dog what they dont
