What ignition is this?
Hey guys, I was screwing around on FB marketplace and came across this boat with a "Corvette engine". Normally I roll my eyes when I see that, but this does in fact appear to have an LT1 in it, minus the optispark. What ignition is this thing running, and how hard would it be to get into a car? Thanks!
Found this:
1999 Cadillac Deville
https://teamtalk.mastercraft.com/showthread.php?t=39965
GMPartsDirect.com(These are guaranteed to be correct and are OEM(read most expensive))
Bracket - Distributorless ignition- 94-99 MSRP $65.98 Your Price $34.32
Ignition Module - Distributorless ignition- 94-99 MSRP $815.08 Your Price $423.84
Coil - Distributorless ignition- 94-99 MSRP $77.16 Your Price $40.12
Seal - Distributorless ignition- 94-99 MSRP $2.08 Your Price $1.08
Screw, COI - Distributorless ignition- 94-99 MSRP $1.62 Your Price $0.84
Alternatives
(Sourced from SummitRacing.com)
Coil Pack - ACCEL
P/N = 140017
Part Type = Ignition Coils
Product Line = ACCEL AC/Delco Style DIS Super Coils
Summit Racing Part Number = ACC-140017
$ 42.95
Coil Pack - MSD
P/N = 8224
Product Line = MSD Blaster OEM Replacement Coils
Summit Racing Part Number = MSD-8224
$ 44.95
Ignition Control Module
P/N - LX362
Summit Racing P/N - SMP-LX362
Product Line - Standard Motor Ignition Modules
Price - $225.99
Napa Online (sourced from napaonline.com)
- Ignition Control Module
Product Line = Echlin Ignition
P/N = ECH TP415
Price = 279.00
- Ignition Coil
Product Line = Mileage Plus Electrical
P/N = MPE IC39SB
Price = 26.99
- Ignition Coil
Product Line: Echlin Ignition
Comments: 4 Terminals
Per Car Qty.: 1
P/N = ECH IC39
Price = 53.49
- Ignition Coil
Product Line = Delphi Engine Management
P/N = DEM GN10123
Price = 61.99
Here are some pics of my Coil Pack unit pulled from the motor. I have pretty much determined this is a ICM issue because of some corrosion I found on the male prong for the specific cylinder I have been having problems with. I am going to try and clean up the ICM and reinstall everything (using Di-Electric grease to assist in corrosion prevention) to see how she runs. If need be, I have all the info I need to start swapping out parts to get the mis-fire problem under control.
Pictures Legend:
1st - Coil Pack/ICM unit mounted on the motor. (just follow the spark plug wires to find yours)
2nd - Coil Pack/ICM unit removed from the motor.
3rd - Coil Packs (4) removed from ICM.
4th - ICM unit.
5th - ICM prongs up close with seal removed (showing minor corrosion)
Alternatives
Coil Pack - ACCEL
P/N = 140017
$ 42.95
Coil Pack - MSD
P/N = 8224
$ 44.95
P/N - LX362
Price - $225.99
P/N = ECH TP415
Price = 279.00
- Ignition Coil
P/N = MPE IC39SB
Price = 26.99
- Ignition Coil
Per Car Qty.: 1
P/N = ECH IC39
Price = 53.49
- Ignition Coil
P/N = DEM GN10123
Price = 61.99
Pictures Legend:
4th - ICM unit.
I love your avatar Mike!
If you're looking for a less spendy option, I've been working on a arduino based coil per cylinder setup for the past couple years that picks off the opti signaling. It's still in the experimental / test stage but I feel like I'm really close to fixing the last outstanding issue. I've been looking for ppl willing to test for months with no takers.
www.gearhead-efi.com/Fuel-Injection/showthread.php?6767-DIY-LTCC-or-similar-system-for-LT1s
