For my 96 LT4 - long tube headers or LT4 hotcam?
#41
Pro Mechanic
No, a cam most certainly does NOT "need" long tubes. Especially in the case of a car with an already efficient exhaust. That post is implying that a cam won't work (meet goals) w/o headers and that is pure BFS.
Red 91 (04-06-2020)
#42
Pro Mechanic
Way back in the day, I swapped a cam in my first car; an '83 Trans Am. I bought a Summit brand cam and lifter kit for $89.99. I put it in myself and that was IT. No springs, no rockers, no tune/jetting, nothing....literally just the cam and lifters, intake, valve and timing cover gaskets. I picked up a full second and 9 mph in the 1/4. Can't beat it.
#43
a cam will not be nearly as effective without long tubes. Anyone who knows anything knows that much. Get out of here bro. Not a chance I'm installing a cam without long tubes and exhaust first.
#45
Pro Mechanic
What I said was (pay attention, here)....
#46
I read in Vizard's SBC book that porting and polishing internals of the cast iron exhaust manifold provided 2/3 the hp as long tube headers. An outfit ( I think CA) does this for $369, including slurry honing. Nice sleeper touch and no installation headaches.
#47
96 lt4
I’ve some experience modifying the C4 LT’s, my current car is a 96 LT4 coupe. The old adage about “how much power do you want, how much money do you have” is quite true. I have always encouraged the package approach and don’t half *** stuff. I encourage guys to be patient and PUT SOME MONEY ASIDE. Be cognizant of thinking air in, air out. I recommend doing a “package” approach because people are often disappointed with the power from a single mod like headers. If you’ve a stock engine, recognize there are certain constraints. I would start with air box/cleaner, TB, good quality shorty headers and cat., and a stainless exhaust from a reputable manufacturer. Then, very importantly, find a tuner with some experience on the OBD2. Doing these mods together will have a more satisfying seat-of-the pants feel. The next “package” is to do a cam with the appropriate intake and heads porting. Putting a big cam in a stock engine is kinda dumb because of the inefficiency/restriction of the other stock components, you leave lots of HP behind and burn a lot more fuel. Good luck with your project!
#49
It's called an LT4 Hot Cam for a reason. A Hot Cam kit will give you everything you need, springs and cam, Reuse the stock 1.6 roller rockers and roller lifters, Spring for some new valve stem seals and you're good to go. Your not gonna get more bang for your buck. When I did my Hot Cam in my LT4 I also sprang for a set of new lifters and a new timing chain. As close to a true "drop in" as you're gonna get..
