fuel pressure
fuel pressure
car turns over, but wont start, smells rich. looked at my fuel pressure
gauge it reads 80 psi. turned car off and it stayed at 80 psi, pressure
didn't drop with key off. will not go lower then 80 psi. this is a tpi
NavAir is right on that one.
As well I would check your FPR. It is easy and fast to do as you simply unhook the rubber vacuum line connecting to the FPR and smell for gasoline. The smell of gasoline indicates a bad diaphragm in the FPR. The ethanol in gas literally eats holes in diaphragm. Fortunately their are not too hard to replace and the parts is about $100 now days. The new ones are tolerant of ethanol so they should last longer.
I have never seen pressure that high in an L98.
I'd go with the stock one unless there is some good reason to up the fuel pressure.
This time around it is because I have a Supercharger, supporting mods, and I am going to start doing a custom tune soon so I may choose to run a higher pressure. With that said, if you put an adjustable one in, there is always the option to adjust your FP if needed later. If not, it can be set to factory spec and left alone as well. Prevents possibly needing to do the job twice later.
If I have ever replaced one, I have always went adjustable. The cost difference didn't matter as much as the time to take the plenum out and put it back on again.
TPI BOY (03-02-2020)
Definitely will use an adjustable on forced induction. Is there much more to be gained with higher pressure? I just let the tuner set the pulse width based on the sensor readings. I'm sure he could set it for higher pressure but is the gain significant? Unless you have injectors that are smaller than should be?
If you double the fuel pressure you only get 41% more fuel.
To double the fuel you need to increase base fuel pressure from 45 psi to 180 psi. Then add pressre from boost on that.
So if you have 15 psi boost you should need about double the fuel. To do that with pressure alone you need to go from 45 psi to 195 psi. ( what the pump see )
When increasing fuel pressure you also reduce flow from the pump.
When more fuel is needed larger injectors is the way to go.
Just like playing with the timing, one or two PSI isn't going to make any significant difference.
It isn't supposedly, injector spray pattern can be observed.
To know for sure, you would really have to get on a dyno and adjust it and see the results on your car and find what works best. In the end, Fuel Pressure alone can't be your only means to increase fuel flow capabilities of your fuel system.
From my research, it's best to think in terms of MAP. If your injectors idle at 38psi... or in Absolute pressure that is 262Kpa into a manifold at 40Kpa. There is a 220kpa pressure differential, but when you crack the throttle to WOT and hit a near 90Kpa or so in the manifold you need the Fuel pressure to step up to match that differential. Even more so if you are boosted. Essentially trying to maintain a linear pressure differential. Hence why the regulator references manifold pressure. Im more simpler terms, if you have 45PSI in your fuel rail, and when the injector opens there is 10PSI in the intake manifold, there is actually a net 35PSI pushing on the fuel. Doesn't matter is you are FI or NA, there absolute pressure in the manifold changes and different combos will run different manifold pressures.
In my particular case, I am boosted, non factory pump, and non factory injectors on my L98. While there is a possibility factory fuel pressure may be the right setting, but there is probably a real good chance it is not.
This link should help.
Also... and Ford related, but its the best reference I could find quickly - Kenne Bell tech tips for Mustang Blowers. Good section on fuel pressure.
However, even if the pressure differential changes, based on feedback the ECM can make pulse width adjustments but the differential can start affecting the spray pattern.
Received 1,404 Likes
If its a lot of fuel, then injectors. If you need to tweak at the strip or track or whatever without doing a retune of the chip, the AFPR. I have both, mine is a TPiS.
At less that WOT, in closed loop, the additional fuel flow will be adjusted for by the ECM in the BLM/INTs to still hit the target A/F. The better automization here would most likely show up in MPGs rather than power
At WOT you will see it richen the mixture more, but this shouldn't be your means to tune you fueling only.
I would definitely agree with that. I would rather not increase fuel flow by cranking up pressure. I'd prefer to work on the pump volume and injector size and of course, pulse width but I suspect that the improvements are used to sell AFPR units and more placebo than actual gains.
That is a whole different animal than what most people will run though. Kinda why I wondered if there is any real gains. I would be looking to do it if I could see something concrete that would pay for itself in either mileage or power.
I'd probably say that at that point, maybe the entire program should be re-written or at least heavily revised?
I really do link this to a similar situation as asking what base timing does my engine run best with? +/- a few degrees isn't going to make a huge improvement but can definitely show up. If major changes in timing need to me made, it needs to be made in the tune.
Same for fueling. Based off manifold pressure (s) your combo runs at, the injectors will probably like to be in a certain sweet spot and can show some improvements, but anything major needs to be addressed in the tune or components. The 22/24lb stock GM units, pump, and tuning are not going to support a Heads/Cam/Blower car making 500hp no matter what you set your pressure at.
https://instrumentationtools.com/flo...-root-delta-p/
End statement:
Generally we use the above simplified equation for all the differential pressure based flow meters like orifice, venturi, flow nozzles, V-cones, segmental wedges, pipe elbows, pitot tubes, etc. which is Flow Directly Proportional to Square Root of ΔP.
When doubling fuel pressure, you double delta P. Flow increase = sqrt(2) = 1.41 = 41% more.
