Service Engine Soon LIght "Code P0400" ?????
Old 11-07-2002, 02:03 PM
Rome856
Rome856's Avatar
Default Service Engine Soon LIght "Code P0400" ?????
Any help would be greatly appreciated.
I have a 96 Camaro Z28 and the Service Engine Soon light came on,
I work at a import car dealer and one of the mechanic used a scan tool and pulled the code P0400 EGR System Malfunctionm, not being a import they are unsure what this could be ( is too rich, too lean etc.)
The forum has always been very helpful when I owned my Corvette so I figured maybe some one might have some helpful information.
Thanks again :seeya
Old 11-07-2002, 02:12 PM
Dan Parker '96
Dan Parker '96's Avatar
Default Re: Service Engine Soon LIght "Code P0400" ????? (Rome856)
My bet goes to a bad EGR solenoid valve (not activating to supply vacuum to the EGR valve) or a bad EGR valve itself.
I had this code intially when I first got my car. A Mity-vac test on the EGR valve showed the diaphram to be bad. Quick replacement and all was good.
You need to see if you're getting a vacuum signal to the EGR valve. If true then check the EGR valve itself.
That should be a good starting point.
Old 11-07-2002, 04:12 PM
bogus
bogus's Avatar
The quick way to diagnose this - clear the code. then, start the car. If the code comes back immediately, then its the control valve, if it takes a while, its the EGR itself.
you see, the computer will sence a bad control valve during initial self test at startup, but it won't find the EGR until it goes into closed loop...
To Service Engine Soon LIght "Code P0400" ?????
Quick Reply: Service Engine Soon LIght "Code P0400" ?????
