Flickering Interior lights/Alarm problem
Old 10-31-2002, 02:50 AM
Black ZR1
Black ZR1's Avatar
Default Flickering Interior lights/Alarm problem
The interior lights on my 91 Vert flicker. Especially when I accelerate. I noticed the warning 'door ajar' comes on, even though the doors aren't ajar.
In the middle of the night, the alarm goes on and off at random. I'm guessing the alarm thinks the door is open since the lights flicker, as if someone was tampering with the door.
Any clues?
Old 10-31-2002, 03:13 AM
VETTENV
VETTENV's Avatar
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: Flickering Interior lights/Alarm problem (Sensei Earl)
My interior light flickers when I hit a bump in the road. I'm thinkin' that maybe the door need adjusting. Hope somebody knows.......... :crazy:
Old 10-31-2002, 08:41 AM
Mr Mojo
Elite Torch Red Member
Support Corvetteforum!
Mr Mojo's Avatar
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Check the door switches, this happened to me also. In my case the switch for the hatch was faulty.
Old 10-31-2002, 08:43 AM
Steel Blue 91
Steel Blue 91's Avatar
Default Re: Flickering Interior lights/Alarm problem (Mr Mojo)
Check the door switches. They may need ajusting or replacement.
Old 10-31-2002, 09:49 AM
92TripleBlack
92TripleBlack's Avatar
Default Re: Flickering Interior lights/Alarm problem (Steel Blue 91)
Its a bad door switch. They look like plunger buttons, black. One for each door and one on the hatch. Could just be loose or just need adjusting and not replacing.
Old 10-31-2002, 09:54 AM
vettmech
vettmech's Avatar
Default Re: Flickering Interior lights/Alarm problem (92TripleBlack)
Hinge pins and bushing time :seeya
Old 10-31-2002, 10:41 PM
dlmeyers
dlmeyers's Avatar
Default Re: Flickering Interior lights/Alarm problem (vettmech)
Until you get the problem fixed, recommend you lock the doors with the keys, this does not arm the system. Electric door lock button arms the system.
Maybe for a test, dark area, start to wiggle/giggle, bump door. See if interior lights come on. Same thing back by hatch. Open doors, grab outside edge of door and lift vertically, checking for play. Also, check the little plastic stops for the door open/closed switch.
My money says left door ajar switch or pins/bushing.
Sweet dreams.
dlmeyers 90 coupe zf6 3 speed shocks
Old 11-02-2002, 12:48 AM
R23HTC
R23HTC's Avatar
Default Re: Flickering Interior lights/Alarm problem (dlmeyers)
Door or hatch switches need checking. Since you're getting the door ajar light when the doors are closed, I would bet it's one of the door switches. :yesnod:
Old 11-02-2002, 03:01 AM
BlackbirdZ07
BlackbirdZ07's Avatar
Default Re: Flickering Interior lights/Alarm problem (R94 LT 1)
If you look at the switches in the doors, you see a small pin in the plastic plunger. The small pin is what actually contacts the body and turns off the lights. If the pin is too far in the plunger, the plunger won't be pushed in far enough. With a small flat blade screwdriver, pry both of the pins out slightly.
Old 11-02-2002, 03:17 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
I would service the driver's "door ajar" switch first.
Mine flickers occasionally but not bad enough yet to set off the alarm when parked and locked.
Old 11-02-2002, 08:37 AM
C4ForGeeGee
C4ForGeeGee's Avatar
Pull that small pin out a little on the doors. I had the same problem, I learned after I adjusted the door pins not to slam my doors. It was free info. I received here on the forum :yesnod: it worked
Old 11-02-2002, 09:03 AM
Mr Mojo
Mr Mojo's Avatar
Not in my case, I disabled the PKE and it the alarm still went off, the only way I solved it temporarily was to pull the fuse.
To Flickering Interior lights/Alarm problem
Quick Reply: Flickering Interior lights/Alarm problem
